Express vpn app question
willyburz
Just test driving express vpn for our android phones. Question is for my chromebooks though...I have a chromebook pixel, and two other chromebooks. Is it as simple as downloading the app on them, logging on, choosing a location, and flipping the switch on, with the app?!
Yes. You can download the app on all devices but you are limited to using this VPN in only 3 of them at the same time if I still remember correctly.
Or you can setup their .ovpn files in your router and then every device will be covered.
