ExpressVPN - Construct .ovpn config file for Dedicated IP Address
PC Pilot
I'm looking for some guidance regards compiling an .ovpn file for use on Merlin Firmware as a VPN Client.
I recently purchased a Dedicated IP address from ExpressVPN with the expectation of a link to an .ovpn configuration file to replace the 'location specific' version already in use as I had also previously experience with Nord VPN who provided an appropriate file for their Dedicated IP Address assigned upon purchase of same. Contacting ExpressVPN I was disappointed to learn that they had not made provision for an .ovpn file for their Dedicated IP Addresses....
This got me to thinking that it was likely possible (given sufficient knowledge!) to construct/compile one based upon the generally available location specific files (as attached) but incorporating the custom configuration text, certificates/key and cipher settings alongside of the assigned IP Address provided in the regular address format xxx.xxx.xxx.xxx.
So, put simply, can any of the amazing experts here on SNBForums point me in the right direction toward compiling a suitable script for use with the VPN Client setting in Merlin installed upon an Asus AX88U router.
Many thanks in advance.
PC Pilot
