Feature request - enable/disable forwarding of certain ports
netware5
Dear Merlin,
Recently i realized that it is not possible to disable certain port forwards from the list in GUI. The only way to disable certain forwarding rule is to delete it from the list in GUI under WAN > Virtual Server / Port Forwarding. So if you need the same rule later, you should enter it again.Sometimes it is very useful to temporary disable certain forwarding rule but keep it in the list and then just enable it when needed. Similar feature exists in Tomato FW. Would you be so kind to consider such new feature in the next versions of your FW?
Any thoughts on adding this feature? dd-wrt also supports it, and is one of just a couple of things I miss about running dd-wrt on my router. (obviously doesn't outweigh all the great stuff about asuswrt-merlin, but would be a nice addition)
In the same vein, what about adding the ability to edit exist port forwards? (and also existing DCHP lease, port triggers, etc.)?
Thanks RMerlin
Would require major low-level changes to the way the webui is implemented, which is beyond the scope of this project, and would make it difficult to stay in sync with future changes from Asus.
Sent from my Nexus 4 using Tapatalk
