First post but quite the lurker...
I switched my FIOS connection from coax to Ethernet Saturday and can't seem to make it work directly from my router. When running the ethernet cable into the Verizon supplied router (Actiontec MI24) it works perfectly with my router (Asus RT-N16) connected to a LAN port on the actiontec. If I move the ethernet cable from the Actiontec WAN to the N16's WAN I can successfully renew my lease and get an address from Verizon's network. Unfortunately I get a ton of dropped packets (ping to google) and the port seems to reset itself quite often. Internet is totally unusable.
The merlin firmware is pretty much stock. I set my password, set the WAN to get an IP address automatically, and setup the wireless. That's it. Tried to post the actual log entries but cloudflare is blocking it. In a nutshell I get entries, all within 8 seconds, that say port1(vlan1) goes from disabled, to listening, to learning, then a topology change is detected and propagated, followed by the port entering forwarding state. It then reads the host file 2 seconds later followed by a "WAN Connection" message that the "ISP's DCHP did not function properly". A ping test during that time shows 40% packet loss on 5 packets sent.
Any ideas? Some folks on another site (dslreports) suggested that VLAN tagging was causing the issue but I've verified (via robocfg) that the WAN port is untagged. The LAN side appears to be but not the WAN.
Also in terms of troubleshooting I've released and renewed addresses, cloned MAC from the Actiontec, powered off for 10-15 minutes, and get the same results using Tomato on an ASUS RT-N66U.
Thanks in advance.
Thanks in advance.
