Firmware RT-AC66U B1 9.0.0.4.386_41994
grenon.andre2021
Hi
Since this feb 2021 beta update, my WAN LED come RED after reboot and Power LED start BLUE on reboot and come OFF at the end of the reboot process.
Any one know when the full release will be available or tell me what should i do to fix this issue.
My internet look to work find and no error on the system log.
The WAN red light is an indication of internet connection failure. May not be true indication as DNS failure can cause the same indication. I had this happen last week on an AC66U_B1 and changing DNS servers fixed the problem.
Edit: as for the next release? Any time now. I suspect the newest hardware version of the AC68U may be causing some issues in getting a firmware that will work across all versions (AC66U_B1 uses the same firmware as the AC68U)
I would reset the router and start fresh. I have one AC66U B1 here and it works properly with 41994.
Hi, good point, i tried changing to 8.8.8.8 and take out DDNS also, same result afert reboot. I will way for the new release of the firmware. thanks
i would prefer not, will see after next firmware release if still the issue is present
Most likely it will be, because whatever is wrong now in nvram will be transferred to the new firmware. As I said above I have one AC66U B1 on 41994 as we speak and it has no issues with WAN or Power LED. It's up to you to decide what to do with your router.
Hi
Very strange, last night, power failure, for about 4 hours, that let the provider modem batteries also to drain to Zero
this morning, all light come back to Blue and power light is ON.
What can I say, thanks
