Firmware updated but not displayed - how to fix?
chichow
So I am running the latest stable version 66_6
but on the splash page I see
Operation Mode:Wireless router Firmware:380.65_4
I went from 65_4 to 66_0 and then 66_6
What is the suggested way to have the splash page show 66_6? At this point all I have done is reboot the router from the admin screen.
Thanks much
Reboot the router with no USB drive attached, then flash. If it still fails, then make sure you downloaded the correct model.
I am thinking I AM running 66_6 just that it is not reflecting properly on the home page.
If I click to the administration page, then to the firmware upgrade tab it DOES show firmware 380.66_6
Are you running any add-on that makes your router use a copy of the www directory?
