Firmware upgrade Aswert-Merlin RT86U ver 12 to 12.4
jgeymont
Upgraded to version 12.4 but cannot log into my router now. Seems to be working but cannot open 192.168.50.1
Better post questions about your issues in the release thread.
Mention what troubleshooting steps you have performed already, if any.
I've experienced a fair bit of WebGUI crashes and other shenanigans (Aimesh nodes crashing, my computer connects to the main node where I barely have signal) immediately after firmware update on the later Merlin versions on my AC86U.
Simply logging in and rebooting through SSH via a LAN client solves it for me (if you have easy physical access, you can reboot it manually). If you don't have SSH set up, do this for next time (there likely will be a next time).
I'm not sure if it is reachable through OpenVPN/wireguard in this state, so if you're not on the LAN, you have to try and see (please report back the result).
Turns out the did not complete fully because the router did not reboot when I thought it had. After rebooting, I was able to log in and everything is fine. Thanks!
