FlexQoS FlexQoS 1.5.3 - Flexible QoS Enhancement Script for Adaptive QoS
ExtremeFiretop
Release Notes for FlexQoS 1.4.7 production release now available
[2025-June-15]
The fork from @dave14305 's repository is now hosted on the AMTM-OSR GitHub repo:
1) Re-enable develop branch for script development.
2) Allow script to remain in failed update process as reported by @maghuro here: Improvement regarding update #1
-Previously the script would uninstall itself in a failed update.
3) Added warning for users installing on 3006 routers without functioning QoS in PR: Add Warning Messages for Adaptive QoS #8
-Warnings may take anywhere from 15 seconds to 3 minutes after install to display. Example screenshots below:
Based on the discussion in the 3006.102.5 beta thread, this should become a hard failure instead of a warning. It seems it is no longer safe to install FlexQoS on the newest GPL code.
In a laughable bit of irony, I can’t even fork the new OSR repository for a PR since I already have the original repo under my name. So someone else will need to give it a go. There is already a check for rc_support during installation, but a new negative check for wifi7 needs to be added.
Thanks for bringing this to our attention Dave. It's always appreciated. We can turn it into a hard fail instead of a soft warning.
Haha that is funny.
You could technically just unarchive it? and then start submitting PRs to OSR that way if you so choose :)
I still can’t fork the OSR repo, and adding branches to my original repo feels awkward since OSR is a fork of my repo. Seems it’s technically possible, but better to let the original lie dormant.
Understandable. We'll check into this news for FlexQoS later this evening.
Haha that is funny.
Yeah, I tried and failed drastically to have FlexQoS on my router. Twice, first at the beta update, and then replicated it and found out that FlexQoS was the reason of failure. I was practically just holding on to it just in case a fix would ever come.
I have no way to fetch any suitable logs (that I know of) to point into the right direction of why it fails so terrible now, but could install on previous firmware without drastic failures (other than its own failure).
As it looks now, BE-routers and functional FlexQoS might never happen anyway. So better block attempts to install it.
Release Notes for FlexQoS 1.4.8 production release now available
[2025-July-10]
What's changed/new?
v1.4.8 (18-May-2025)
- CHANGED: Changed the soft warning for hard block on WiFi 7 devices as per dave and RMerlin conversation here: https://www.snbforums.com/threads/asuswrt-merlin-3006-102-5-beta-is-now-available.95115/post-961105
- CHANGED: Added a force uninstall for routers with FlexQoS installed on BE devices while rebooting/startup
Thanks @swejuggalo for reporting. A hard block has now been implemented for WiFi 7 devices.
Only WiFi 6E or below will be allowed to use FlexQoS moving forwards.
[2025-July-10]
What's changed/new?
- CHANGED: Added a force uninstall for routers with FlexQoS installed on 3004 F/W while upgrading to 3006 F/W
Hurrah! No more break downs 😉
Summary of FlexQoS usefulness:
WiFi5 (ac) - rock solid
WiFi6 (ax) - so-so if you can live without either iptables rules or flow cache (hw acceleration), less than 400 Mbit ISP service.
WiFi7 (be) - crashes your router on the latest firmware
I'm curious to see what ASUS plans for QoS replacement in WiFi 7 (be) devices.
Never really used it when it was in it's "glory days" (when I used a AC router).
It's was more a fun experiment to even take a look at it.
Glad I crashed so others would not 😉
As the demise draws nearer, it is a fun trip down memory lane to revisit the origins of the original custom QoS script that started it all. I only took over in 2020 after FreshJR disappeared or died.
The QoS problem is largely solved on other platforms like OpenWrt. They have solutions for general use, gaming, classifying traffic up the wazoo, whatever you like. Classify it on egress and it can automatically classify the return ingress traffic the same way. Gamers get better “ping” from the HFSC qdisc than CAKE.
Hopefully they are following a similar path, and I see hints in the source that suggests the ingress issue is being developed, but I really don’t know their plans. Dumping Trend Micro would be a good start.
Is it possible to add some kind of timer, where I can schedule... Things?
Like completely turn off Qos from Xh and turn on at Yh.
Main reason for that is that I'm super conservative regarding bittorrenting large legitimate files from and to my workplace 🌝
But I want FULL POWER between some hours of some days, where everyone (both in home and in company🌝) are asleep.
Is that possible at all?
Hi @maghuro
Sorry for the delay in responding, I got busy with other work, and I didn't really want to give you an answer until I had something (working or not)
Currently I have something in "alpha" stage ready for you to try. PR is here: https://github.com/AMTM-OSR/FlexQoS/pull/16
It took me a bit; but gave me something fun to work on while I had some free hours.
I have not merged the changes into the develop branch yet, as I'm still not fully confident in this solution and if it addresses your request completely.
Please give it a try by running the following to do a fresh install; and letting me know if you find any bugs over the next few days of testing, and if it addresses your request:
/usr/sbin/curl "https://raw.githubusercontent.com/AMTM-OSR/FlexQoS/Start_Stop/flexqos.sh" -o /jffs/addons/flexqos/flexqos.sh --create-dirs && chmod +x /jffs/addons/flexqos/flexqos.sh && sh /jffs/addons/flexqos/flexqos.sh -install
Hi @maghuro
@ExtremeFiretop
I appreciate the continued support for Flex...much appreciated. I might set something up to test it
@ExtremeFiretop
Yes absolutely the more testers the better! I don't usually use QoS myself, but I turned it on with my Gnuton router to test the solution while developing it, and it seems to work for me throughout the quick tests I did.
Of course this is just my interpretation of what @maghuro wanted, but if it can be improved I'm open to suggestions.
Thanks again!
Thanks again!
My dear friend,
First of all, sorry for the late answer. I'm on vacation (finally!) and I'm trying to be offline for some days 😅
Thank you for your quickly and hard work. Remotely, I'm not confident to test things, so as soon as I return home I'll test it properly.
Thank you once again 🙏🏻
Well, I couldn't wait to test it... My bad, family 😅
One thing I noticed is that it won't trigger a start/stop immediately after setting the schedule. I mean, it's 4AM right now. I set QoS to disable at 1AM and enable at 8AM. It didn't stopped after I set the schedule, only manually.
Another picky thing I suggest is the possibility to have multiple schedules possibility (or at least two). The main goal is for weekdays and weekends (I think two schedules is sufficient, regarding that kind of days).
Also, I haven't tested it, but when turning on/off does it flush cache? Does it restart firewall? So all the clients and connections are updated on the fly?
Thank you once again 😀 🙏🏻
