FlexQoS FlexQoS 1.5.3 - Flexible QoS Enhancement Script for Adaptive QoS
Update:
Until 3006.102.4 & betas I always did a reset and tried but Flexqos never worked and result was intermittent freezes and Internet failures.
On 3006.102.5 I did a dirty upgrade and flexqos still did the same so I didn't bother to reset the router (AX88U Pro) & uninstalled Flexqos.
@ExtremeFiretop and @Kingp1n suggested to remove IP Table rules which worked.
So I did a WPS reset and installed flexqos. But WPS reset didn't clear everything and I had difficulty doing SSH and accessing router GUI.
So I again did a complete reset from within the GUI and installed flexqos again. Now it's been more than 24 hours and everything is working flawless (no I did not remove any default rules).
I think it's safe to assume that Flexqos is still OK for AX routers.
Will let you all know if I run into any problems later
I won't take any credit for @dave14305 's idea. I'm not sure what would of caused that issue/conflict exactly, but I'm happy it appears to be working after the reset!
As someone once said: no news is good news.
I've been trying to catch something to talk about but hey, I haven't found anything 😅
Everything is working smoothly with my two schedules , one for weekdays and the other one for weekends.
The only picky thing I have is when I want to change one particular schedule, I have to configure them from scratch. But that will happen once in a year, so that's not even a issue.
Everything is smooth!
Thanks once again for your work
Hi @maghuro
Based on your feedback; I've made some more changes in my PR and finally merged it into dev branch.
At this point I would call it "beta" testing instead of "alpha" testing ;)
You can run the following to get the latest develop version:
sh /jffs/addons/flexqos/flexqos.sh develop
Below are some sample screenshots of the implementation thus far...
Please test some more to confirm this addresses all your requirements and doesn't have any unforeseen bugs I didn't catch.
-SSH
-WebUI:
Hi @maghuro
-SSH
-WebUI:
Thank you, very nice work!
One thing I noticed already is when I set something to some value between two hours, it only assumes the hour and sets the minutes to zero.
For example, I set a cron to start as 07:45 and it was set to start at 7h.
On the GUI, it assumes 07:45 as you can see, but the cron stays at 7.
================ QoS Schedule =================
Saved schedule records:
  1) [ON] DOW=1-5  06:45 -> 00:00
  2) [ON] DOW=0,6  09:00 -> 02:00
Active cron entries (if any):
  0 6 * * 1-5 /jffs/addons/flexqos/flexqos.sh -qosstart #flexqos_qoson_1#
  0 0 * * 1-5 /jffs/addons/flexqos/flexqos.sh -qosstop #flexqos_qosoff_2#
  0 9 * * 0,6 /jffs/addons/flexqos/flexqos.sh -qosstart #flexqos_qoson_3#
  0 2 * * 0,6 /jffs/addons/flexqos/flexqos.sh -qosstop #flexqos_qosoff_4#
Choose an option:
  1) Create schedules (Guided)
  2) Add a schedule
  3) Edit a schedule
  4) Delete a schedule
  5) Clear ALL schedules
  e) Exit
Enter selection: 3
Pick schedule # (1-2, or e=exit): 1
Editing schedule #1
Enable? (1=yes,0=no) [1]: 1
Days of week (e.g., *,1-5,0,6) [1-5]: 1-5
START time (HH or HH:MM) [06:45]: 07:45
END time (HH or HH:MM) [00:00]: 00:00
Updated and applied.
  1) [ON] DOW=1-5  07:45 -> 00:00
  0 7 * * 1-5 /jffs/addons/flexqos/flexqos.sh -qosstart #flexqos_qoson_1#
Choose an option:
  2) Add a schedule
  3) Edit a schedule
  e) Exit
Edit: however, I tried to set this schedule through webui and it was set correctly (after that, I checked via ssh and it was correct)
Great catch! @maghuro ! This should now be addressed :)
I was actually more focused on the WebUI recently; so it's clear to me I missed this originally.
Was a bit of an oversight on my original flow I had planned in my head; I actually was only considering hours and dropping the minutes over SSH.
Re-downloading the latest develop version should solve this report. Let me know! :)
@maghuro[/USER]
-SSH
-WebUI:
This looks like very promising/interesting.
I will surely have a look later because I really like the idea of scheduling QoS.
Thank you very much for the hard work and for people that are proposing brilliant idea that can be useful for others.
Was a bit of an oversight on my original flow I had planned in my head; I actually was only considering hours and dropping the minutes in SSH.
Perfect! Nothing to declare !
GREAT job. I was checking your code and it's a brilliant implementation
Hi @maghuro
Seems all is working well with "beta" testing for qos scheduling. Cool feature. Hope youre able to realase as stable soon.
I appreciate the continued support for FlexQoS!!
I noticed an "issue" with the scheduling UI on some browsers specifically, while most are fine the spacing for others is a bit off.
so I'm currently pondering the best way to handle it. 🤣
Situation:
All traffic (only ipv4, I don't use ipv6) from a specific machine is manually redirected to the Work-from-Home rule (yellow). It correctly shows on the table (screenshot1)
However, on the graphic, it isn't applied. I run a test from fast.com (netflix speedtest), and all the traffic, on the graphic, shows on Video/Audio streaming (green) category (and net control packets? :( ). (screenshot2 during a fast.com test)
My rules are on screenshot3.
I'll send you via pm the debug from flexqos.
Thanks in advance!
That’s normal for iptables rules to be ignored on the latest models due to flow cache. It’s been discussed for a couple years already.
Release Notes for FlexQoS 1.4.9 production release now available
[2025-Sep-05]
The fork from @dave14305 's repository is now hosted on the AMTM-OSR GitHub repo:
What's changed/new?
v1.4.9 (05-Sep-2025)
- NEW: Includes Flexible/Dynamic Scheduling of the QoS system on ASUS routers.
- As requested here by @maghuro : https://www.snbforums.com/threads/f...ent-script-for-adaptive-qos.94976/post-964632
- NOTE ON BROWSER LIMITATIONS:
Currently all web browsers have a "Time Picker" Widget except for Firefox.
This means that all browser's should have something like this available:
Even mobile browsers show like this:
However Firefox does not and instead only allows text input as found below:
This is not a bug with the code, but a limitation within Firefox.
Screenshots below:
-WebUI:
-SSH
Well I don't know how I missed it, but... 🌝
The new scheduling option should be present in the settings backup... 😅
Good Morning @maghuro
You are absolutely right, working on this now!
I also noticed I didn't do a very good job cleaning up the cron jobs in an uninstall, which will be included in the next release.
Release Notes for FlexQoS 1.4.10 production release now available
[2025-Sep-06]
What's changed/new?
v1.4.10 (06-Sep-2025)
- FIXED: Addressed missing cleanup for any cron job schedules when uninstalling.
- FIXED: Missing the ability to backup the new QoS schedules as reported by @maghuro
[2025-Sep-06]
What's changed/new?
- FIXED: Missing the ability to backup the new QoS schedules.
I tried updating and i'm getting this:
Thanks for reporting, seems to me that there's some kinda check in the script blocks version like 1.4.(10)
I guess the expectation was to go to 1.5.0 even though it's a small patch.
I can either update the code to stop caring, or update the version to be within the expected range.
Considering that your stuck with the old code now, I think I'll do both to be sure this is not a problem in the future.
One momento
Release Notes for FlexQoS 1.5.0 production release now available
[2025-Sep-06]
What's changed/new?
v1.5.0 (06-Sep-2025)
- FIXED: Allow script versions with double-digit segments.
Updated smoothly...
Only thing I noticed is when qos is scheduled it does turn off qos successfully however when I check Flow Cache under System info its showing as disabled. I do use iptable rules and i have Flow Cache Control set to Auto.
I believe this is how FC control works:
Post in thread 'ax88u-pro: need adaptive qos advice for 5 adults on a 300/300 isp' https://www.snbforums.com/threads/a...r-5-adults-on-a-300-300-isp.95307/post-965702
Normally when qos is disabled FC should be Enabled (default).
