Solved FlexQoS problems with Merlin 386.1_2
sbsnb
I've been using FlexQoS for quite some time without issue, but ever since I updated to Merlin's 386.1_2 this morning my log is filling up with these error messages:
Feb 24 16:07:12 FlexQoS: TC Modification Delay reached maximum 300 seconds
Feb 24 16:07:12 FlexQoS: TC Modification delayed for 300 seconds
Feb 24 16:07:12 FlexQoS: Scheduled Persistence Check -> Reapplying Changes
Feb 24 16:07:13 FlexQoS: Applying AppDB static rules
Feb 24 16:07:13 FlexQoS: RTNETLINK answers: Invalid argument
Feb 24 16:07:13 FlexQoS: We have an error talking to the kernel
Feb 24 16:07:13 FlexQoS: Adaptive QoS not fully done setting up prior to modification script
Feb 24 16:07:13 FlexQoS: (Skipping class modification, delay trigger time period needs increase)
Feb 24 16:07:13 FlexQoS: Applying AppDB custom rules and TC rates
Feb 24 16:07:13 FlexQoS: Error: argument "-1" is wrong: invalid priority value
Feb 24 16:12:00 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=2895) called with 1 args: -check
Feb 24 16:12:01 FlexQoS: TC Modification Delayed Start
Feb 24 16:17:12 FlexQoS: TC Modification Delay reached maximum 300 seconds
Feb 24 16:17:12 FlexQoS: TC Modification delayed for 300 seconds
Feb 24 16:17:12 FlexQoS: Scheduled Persistence Check -> Reapplying Changes
Feb 24 16:17:13 FlexQoS: Applying AppDB static rules
Feb 24 16:17:13 FlexQoS: RTNETLINK answers: Invalid argument
Feb 24 16:17:13 FlexQoS: We have an error talking to the kernel
Feb 24 16:17:13 FlexQoS: Adaptive QoS not fully done setting up prior to modification script
Feb 24 16:17:13 FlexQoS: (Skipping class modification, delay trigger time period needs increase)
Feb 24 16:17:13 FlexQoS: Applying AppDB custom rules and TC rates
Feb 24 16:17:13 FlexQoS: Error: argument "-1" is wrong: invalid priority value
Feb 24 16:22:00 FlexQoS: /jffs/addons/flexqos/flexqos.sh (pid=4662) called with 1 args: -check
Feb 24 16:22:01 FlexQoS: TC Modification Delayed Start
Feb 24 16:27:12 FlexQoS: TC Modification Delay reached maximum 300 seconds
Feb 24 16:27:12 FlexQoS: TC Modification delayed for 300 seconds
Feb 24 16:27:12 FlexQoS: Scheduled Persistence Check -> Reapplying Changes
Feb 24 16:27:13 FlexQoS: Applying AppDB static rules
Feb 24 16:27:13 FlexQoS: RTNETLINK answers: Invalid argument
Feb 24 16:27:13 FlexQoS: We have an error talking to the kernel
Feb 24 16:27:13 FlexQoS: Adaptive QoS not fully done setting up prior to modification script
Feb 24 16:27:13 FlexQoS: (Skipping class modification, delay trigger time period needs increase)
Feb 24 16:27:13 FlexQoS: Applying AppDB custom rules and TC rates
Feb 24 16:27:13 FlexQoS: Error: argument "-1" is wrong: invalid priority value
Not sure how to interpret this.
What version of FlexQoS? There are messages in that log that aren’t part of the current version. Make sure you’re on the latest stable version (1.2.1).
Let me check. I've never updated manually. I just kind of assumed it would update itself when it ran its cron job.
That could explain why I went from my usual upload rate (>200Mbps) to a 1Mbps on a specific device... I found that adding a bandwidth limiter with a higher number of bandwidth works as a workaround.
