Force IP from AC86U over windows static ip?
PaulKemp
My headless server is placed on the attic with only power and ethernet, it has a old static IP assigned from within windows, so it now faults to a 169.254.xxx.xxx IP witch is the wrong subnet. Afaik this is how windows handles static ip's that are invalid and cannot get a response from the router.
Id rather not move the machine down, nor move a monitor and keyboard up there.
Is there a way to force either dhcp or a newly assigned static ip from the router? So it takes precedence over the old windows assigned static ip? Thanks!
How should this work?
Your PC doesnt ask for IP as you set a static one on it, DHCP only gets involved if a client asks for an IP.
You dont set static IPs on a router, if in reservation list your router will give same client this IP again and again using DHCP.
