"Format JFFS partition at next boot" cause jffs unmounted
ac66ub1
I use DD WRT to mount the unmounted jffs,then reinstall Merlin 384.5.
But select "Format JFFS partition at next boot" and reboot,jffs unmounted again.
Jun 4 19:25:15 rc_service: ntp 430:notify_rc restart_diskmon
Jun 4 19:25:15 disk_monitor: Finish
Jun 4 19:25:17 disk_monitor: be idle
Jun 4 19:25:18 kernel: Init chrdev /dev/detector with major 190
Jun 4 19:25:18 kernel: tdts: tcp_conn_max = 8000
Jun 4 19:25:18 kernel: tdts: tcp_conn_timeout = 300 sec
Jun 4 19:25:34 kernel: SHN Release Version: 2.0.1 3529123_patch
Jun 4 19:25:34 kernel: UDB Core Version: 0.2.14 r3529123
Jun 4 19:25:34 kernel: Init chrdev /dev/idpfw with major 191
Jun 4 19:25:34 kernel: IDPfw: IDPfw is ready
Jun 4 19:25:34 kernel: sizeof forward pkt param = 192
Jun 4 19:25:38 rc_service: udhcpc 411:notify_rc start_firewall
Jun 4 19:25:39 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Jun 4 19:25:39 dhcp_client: bound 192.168.1.2 via 192.168.1.1 during 604800 seconds.
Jun 4 19:25:42 crond[288]: time disparity of 685585 minutes detected
Jun 4 19:26:43 rc_service: rc 892:notify_rc restart_wrs
I didn't find any bad block message in log.
Before we find the real reason, we cannot find solid solution for this problem.
As to DD WRT can mount JFFS correctly, can I say it's a software problem?
Or that's hardware issue, then return to Asus?
Have you enabled jfs partition in Merlin firmware
You mean koolshare firmware fixed "jffs unmounted" bug?
Done use it it's not a trustworthy firmware, just follow the instructions he gave on formatting because that works in Merlin firmware.
Judging by your posts the issue is more then likely on your end, not the firmware. Factory reset and start fresh.
Yes!
1. First you have to do a factory reset before installing the firmware.
2. After the factory reset, Make a Complete power cycle
3. Turn off router
4. Unplug power
5. Turn it back on for 5 second to drain any residual electric charge
6. Turn it back off
7. Plug back the power
8. Turn it on and let it boot normally
9. Install the new firmware and perform another factory reset.
10. After the factory reset, Make a Complete power cycle
11. Turn off router
12. Unplug power
13. Turn it back on for 5 second to drain any residual electric charge
14. Turn it back off
15. Plug back the power
16. Turn it on and let it boot normally
17. Administration -> System -> Activate these 3 settings
  • Format JFFS partition at next boot: Yes
  • Enable JFFS custom scripts and configs: Yes
  • Enable SSH: LAN only
18. Apply -> Reboot (You have to Apply before Reboot)
Please lets keep things evidence based and not confuse users. There is no documented "JFFS unmounted bug", nor is there anything Koolshare does to "fix" it. His problem is simply user error.
"jffs unmounted" is not a single case for myself,go through other cases from google search, the source of "jffs unmounted" refer to "Format JFFS partition at next boot" .
Just because other people encountered it doesn’t mean it’s not user error...
