FW 388.2 on AX68U 5Ghz Wifi crash
jtp10181
Anyone else seeing the 5Ghz crash on 388.2?
It happened once on beta 2 and now again on the final.
These errors just repeat all night long, cannot see where it started.
Going to pull power and reboot, that should bring it back for now.
EDIT: Just realized these errors are from a few days ago from beta 2 before I updated, but same errors happened last night as well, and 5Ghz is down.
Apr 11 18:56:20 kernel: wl1: PSMx dump at 213649 seconds. corerev 131 reason:watchdog ucode revision 1626.38205 features 0x3106
Apr 11 18:56:20 kernel: psmxdebug 0x0000050f pc_x 0x01ff001f macctl_x 0x403 maccmd_x 0x0
Apr 11 18:56:20 kernel: psmx_brc 0x01c9 psmx_brc_1 0x0000 MX_UCODE_DBGST 0x2
Apr 11 18:56:20 kernel: PC (psmdebug_x):
Apr 11 18:56:20 kernel: 0x50f      0x50f      0x50f      0x50f
Apr 11 18:56:20 kernel: PC (psmdebug):
Apr 11 18:56:20 kernel: 0x1ff0023  0x1d901ff  0x1fd0063  0x1930709
Apr 11 18:56:20 kernel: 0x1ff12c0  0x1ff12c0  0x1ff12c0  0x1ff12c0
Apr 11 18:56:20 kernel: PSMX_STACK_STATUS : 0x8101
Apr 11 18:56:20 kernel: PSMX_STACK_ENTRIES:
Apr 11 18:56:20 kernel: 0x1b02
Apr 11 18:56:20 kernel: 0x050f
Apr 11 18:56:20 kernel: 0x035f
Apr 11 18:56:20 kernel: 0x07e3
Apr 11 18:56:20 kernel: 0x19b4
Apr 11 18:56:20 kernel: 0x3c85
Apr 11 18:56:20 kernel: 0x0943
Apr 11 18:56:20 kernel: 0x1305
Apr 11 18:56:20 kernel: txe_vasip_intsts 0x0
Apr 11 18:56:20 kernel: wl1: fatal error, reinitializing, total count of reinit's[315]
Apr 11 18:56:20 kernel: CSIMON:  CSIMON[1.1.0] Initialization
Apr 11 18:56:20 kernel: CSIMON: M2M usr already registered ...
Same for me, keeps disconnecting, with 388.1 was very stable on the RT-AX88U's
Also, just tried to manually change the channel on 5G and it's not responding, it's stuck at channel 36.
RT-AX88U perhaps?
Doesn't apply for RT-AX68U though - it doesn't have 160MHz support.
Sorry, my bad, you're right, both are RT-AX88U, still channel doesn't change.
You're a hero. After so many issues with this router still fighting with it. Even Asus replaced this model with multiple AX58U hardware variants in AX3000 and AX5400 class. AX68U is the only router with BCM6710 5GHz radio and a long history of Wi-Fi issues. Time to replace it with something better?
No crashes for me since updating to 388.2 for 72 hours. I even get a little stronger 5GHz signal now, too. Even with 386.7_2, I had very stable 5GHz. It was a dirty upgrade from 386.7_2.
I'll keep an eye on things and report back if I have any issues. I bought the router in April of 2022.
Just got it recently (February 2, 2022 - I guess not that recent, but its still new for me), upgraded from an AC56U. Has worked fine besides this recent 5Ghz issue that happened twice. Don't really need anything more powerful.
I had some issues where my firestick and tablet would have a very low TX rate on 5GHz. This happened 3 times in the last 2 days. One time every device had a low TX rate.
Going back to 386.7_2 which has been rock solid for me.
