Fw feature candidates
Landhoff
Hi there
I'm fairly new to this. Been running DD-WRT on various Linksys/Cisco routere for the past 6-7 years. Bought my first Asus (RT-AC66U) a couple of weeks ago and have been running it for a little less times.
In general I find the webui much better in the stock fw compared to e.g. native Linksys. But I miss some things. So I uploaded newest RMerlin fw last weekend (...anyway, what was the latest, when I downloaded the fw = 38_2).
I still miss a few things. So RMerlin, May I suggest a couple of enhancements:
For one, I would like the traffic monitor to be configurable in terms of how to display traffic volumes - like Kb/s, KB/s, Mb/s, or MB/s
Secondly, to me it would be very usefull to have the possibility to enable/disable port forwarding for ports individually instead og having to activate it for all ports/ranges or none.
Is this something you would consider for a future release?
Many thanks for the good work so far.
Regards
Landhoff
You can port forward individual ports at the bottom
Yes, I know. But either I have to activate forwarding of all ports or none. I would like to be able to specify forwarding of a number of ports and at the same time be able to set each port forwarding active or inactive.
regards Landhoff
regards Landhoff
E.g. like this...
Better webui edit features would require some major changes to the way Asus implemented the webui. Not something I intend to do, as it would make it near impossible afterward to keep up with newer Asus releases.
F Several Questions Re:Asuswrt-Merlin Feature Implementation Asuswrt-Merlin 2
