GS108T ping?
Carnagerover
Hi all,
I have a GS108T plugged into a Netgear R6300 router, the GS108T has 5 devices plugged into it, 3 x 10/100 and 3x 100Mbps including a 1000 Mbps uplink connection to the R6300 Router. The R6300 has no other devices plugged into it other than the link to the switch.
When I ping the R6300 router I get the following:
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Users\Stu>ping 192.168.1.1 -t
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=7ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=8ms TTL=64
Reply from 192.168.1.1: bytes=32 time=10ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 41, Received = 41, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 10ms, Average = 2ms
I have never had a smart switch before but normally on any other normal switch I have had when pinging through to my router it is always <1ms. Does this seem a little high, some replies are as high as 10ms. I noticed the other night that my ping was a little erratic and the switch would seem to be the cause.
Any Ideas?
Looks like the R6300 has a part to play, I took my Ubuntu netbook downstairs and plugged a cat5.e straight into the router and got these results:
stu@stu-NC10:~$ ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_req=1 ttl=64 time=8.38 ms
64 bytes from 192.168.1.1: icmp_req=2 ttl=64 time=6.53 ms
64 bytes from 192.168.1.1: icmp_req=3 ttl=64 time=4.88 ms
64 bytes from 192.168.1.1: icmp_req=4 ttl=64 time=3.49 ms
64 bytes from 192.168.1.1: icmp_req=5 ttl=64 time=1.72 ms
64 bytes from 192.168.1.1: icmp_req=6 ttl=64 time=2.26 ms
64 bytes from 192.168.1.1: icmp_req=7 ttl=64 time=3.35 ms
64 bytes from 192.168.1.1: icmp_req=8 ttl=64 time=6.41 ms
64 bytes from 192.168.1.1: icmp_req=9 ttl=64 time=4.70 ms
64 bytes from 192.168.1.1: icmp_req=10 ttl=64 time=2.73 ms
64 bytes from 192.168.1.1: icmp_req=11 ttl=64 time=0.638 ms
64 bytes from 192.168.1.1: icmp_req=12 ttl=64 time=0.599 ms
64 bytes from 192.168.1.1: icmp_req=13 ttl=64 time=0.845 ms
64 bytes from 192.168.1.1: icmp_req=14 ttl=64 time=10.0 ms
64 bytes from 192.168.1.1: icmp_req=15 ttl=64 time=5.51 ms
64 bytes from 192.168.1.1: icmp_req=16 ttl=64 time=3.43 ms
64 bytes from 192.168.1.1: icmp_req=17 ttl=64 time=5.96 ms
64 bytes from 192.168.1.1: icmp_req=18 ttl=64 time=4.67 ms
64 bytes from 192.168.1.1: icmp_req=19 ttl=64 time=2.66 ms
64 bytes from 192.168.1.1: icmp_req=20 ttl=64 time=0.746 ms
64 bytes from 192.168.1.1: icmp_req=21 ttl=64 time=1.75 ms
64 bytes from 192.168.1.1: icmp_req=22 ttl=64 time=0.619 ms
64 bytes from 192.168.1.1: icmp_req=23 ttl=64 time=1.81 ms
64 bytes from 192.168.1.1: icmp_req=24 ttl=64 time=0.579 ms
64 bytes from 192.168.1.1: icmp_req=25 ttl=64 time=1.57 ms
64 bytes from 192.168.1.1: icmp_req=26 ttl=64 time=9.68 ms
64 bytes from 192.168.1.1: icmp_req=27 ttl=64 time=8.57 ms
64 bytes from 192.168.1.1: icmp_req=28 ttl=64 time=2.93 ms
64 bytes from 192.168.1.1: icmp_req=29 ttl=64 time=5.81 ms
64 bytes from 192.168.1.1: icmp_req=30 ttl=64 time=4.67 ms
64 bytes from 192.168.1.1: icmp_req=31 ttl=64 time=1.86 ms
64 bytes from 192.168.1.1: icmp_req=32 ttl=64 time=1.50 ms
64 bytes from 192.168.1.1: icmp_req=33 ttl=64 time=9.72 ms
64 bytes from 192.168.1.1: icmp_req=34 ttl=64 time=7.58 ms
64 bytes from 192.168.1.1: icmp_req=35 ttl=64 time=7.29 ms
64 bytes from 192.168.1.1: icmp_req=36 ttl=64 time=5.72 ms
64 bytes from 192.168.1.1: icmp_req=37 ttl=64 time=3.74 ms
64 bytes from 192.168.1.1: icmp_req=38 ttl=64 time=1.58 ms
64 bytes from 192.168.1.1: icmp_req=39 ttl=64 time=9.71 ms
64 bytes from 192.168.1.1: icmp_req=40 ttl=64 time=8.56 ms
64 bytes from 192.168.1.1: icmp_req=41 ttl=64 time=6.66 ms
64 bytes from 192.168.1.1: icmp_req=42 ttl=64 time=4.89 ms
64 bytes from 192.168.1.1: icmp_req=43 ttl=64 time=3.52 ms
64 bytes from 192.168.1.1: icmp_req=44 ttl=64 time=1.74 ms
64 bytes from 192.168.1.1: icmp_req=45 ttl=64 time=8.04 ms
64 bytes from 192.168.1.1: icmp_req=46 ttl=64 time=8.44 ms
64 bytes from 192.168.1.1: icmp_req=47 ttl=64 time=6.67 ms
64 bytes from 192.168.1.1: icmp_req=48 ttl=64 time=4.70 ms
64 bytes from 192.168.1.1: icmp_req=49 ttl=64 time=2.70 ms
64 bytes from 192.168.1.1: icmp_req=50 ttl=64 time=0.681 ms
64 bytes from 192.168.1.1: icmp_req=51 ttl=64 time=1.69 ms
64 bytes from 192.168.1.1: icmp_req=52 ttl=64 time=1.60 ms
64 bytes from 192.168.1.1: icmp_req=53 ttl=64 time=8.23 ms
64 bytes from 192.168.1.1: icmp_req=54 ttl=64 time=6.99 ms
64 bytes from 192.168.1.1: icmp_req=55 ttl=64 time=4.58 ms
64 bytes from 192.168.1.1: icmp_req=56 ttl=64 time=4.25 ms
64 bytes from 192.168.1.1: icmp_req=57 ttl=64 time=0.531 ms
64 bytes from 192.168.1.1: icmp_req=58 ttl=64 time=3.71 ms
64 bytes from 192.168.1.1: icmp_req=59 ttl=64 time=1.71 ms
64 bytes from 192.168.1.1: icmp_req=60 ttl=64 time=3.66 ms
64 bytes from 192.168.1.1: icmp_req=61 ttl=64 time=0.878 ms
64 bytes from 192.168.1.1: icmp_req=62 ttl=64 time=6.57 ms
64 bytes from 192.168.1.1: icmp_req=63 ttl=64 time=4.64 ms
64 bytes from 192.168.1.1: icmp_req=64 ttl=64 time=2.69 ms
^C
--- 192.168.1.1 ping statistics ---
64 packets transmitted, 64 received, 0% packet loss, time 63086ms
rtt min/avg/max/mdev = 0.531/4.293/10.025/2.786 ms
stu@stu-NC10:~$ ^C
stu@stu-NC10:~$
The Netbook was the only device connected as well so no idea what is going on with it now.
