GT-AC5300 v.3.0.0.4.384_81685-gc7d4330
It's good for me too.
This is the only entry in my logs from the last 3 days since I had it installed, generated every 5 seconds or so:
WLCEVENTD wlceventd_proc_event(466): eth8: Deauth_ind 7C:64:56:90:F6:0E, status: 0, reason: Class 3 frame received from nonassociated station (7)
Google came up with nothing.
Four devices,
Main: GT-AC5300,
Nodes: GT-AX11000, RT-AC5300, AC68U in Aimesh
Ping times from the furthest node (AC68U):
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=14ms TTL=64
Reply from 192.168.1.1: bytes=32 time=16ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Reply from 192.168.1.1: bytes=32 time=10ms TTL=64
