GT AX11000 pro tainted P
mxz800
I have the GT AX11000 pro and always use stock firmware. Anytime I always manually download the latest firmware. In the case, the latest one when check for latest firmware update it says " could not retrieve firmware info/update from server ". This is what my logs show right after I try to check for updates. I've tried all restore/revert back to factory from soft to hard rests, with rescue mode as well. I've seen other similar threads but I don't use Merlin or any other info provided on that thread. Any help would be greatly appreciated. Is this a hardware issue where I should send it in or do you guys have any tips on what I can do to avoid Asus RMA.
WATCHDOG: [FAUPGRADE][auto_firmware_check:(8398)]periodic_check AM 3:24
Aug 5 04:01:49 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8442)]do webs_update
Aug 5 04:01:52 kernel: CPU: 1 PID: 4180 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Aug 5 04:01:52 kernel: Hardware name: GTAX11000_PRO (DT)
Aug 5 04:01:52 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Aug 5 04:01:52 kernel: pc : 00000000f74b78e8
Aug 5 04:01:52 kernel: lr : 00000000f74b7764
Aug 5 04:01:52 kernel: sp : 00000000ffd2e400
Aug 5 04:01:52 kernel: x12: 00000000f75c6c18
Aug 5 04:01:52 kernel: x11: 00000000ffd2e90c x10: 000000000023e044
Aug 5 04:01:52 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Aug 5 04:01:52 kernel: x7 : 0000000000000000 x6 : 00000000ffd2e548
Aug 5 04:01:52 kernel: x5 : 0000000000000000 x4 : 00000000ffd2ef48
Aug 5 04:01:52 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Aug 5 04:01:52 kernel: x1 : 00000000f75c6c18 x0 : 0000000000000000
Aug 5 04:01:52 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8510)]could not retrieve firmware information: webs_state_update = 0, webs_state_error = 0, webs_state_dl_error = 0, webs_state_info.len = 0
Aug 5 04:02:22 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8442)]do webs_update
Aug 5 04:02:25 kernel: CPU: 3 PID: 4333 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Aug 5 04:02:25 kernel: Hardware name: GTAX11000_PRO (DT)
Aug 5 04:02:25 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Aug 5 04:02:25 kernel: pc : 00000000f74cc8e8
Aug 5 04:02:25 kernel: lr : 00000000f74cc764
Aug 5 04:02:25 kernel: sp : 00000000fffe49c0
Aug 5 04:02:25 kernel: x12: 00000000f75dbc18
Aug 5 04:02:25 kernel: x11: 00000000fffe4ecc x10: 000000000023e044
Aug 5 04:02:25 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Aug 5 04:02:25 kernel: x7 : 0000000000000000 x6 : 00000000fffe4b08
Aug 5 04:02:25 kernel: x5 : 0000000000000000 x4 : 00000000fffe5508
Aug 5 04:02:25 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Aug 5 04:02:25 kernel: x1 : 00000000f75dbc18 x0 : 0000000000000000
Aug 5 04:02:25 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8510)]could not retrieve firmware information: webs_state_update = 0, webs_state_error = 0, webs_state_dl_error = 0, webs_state_info.len = 0
Aug 5 04:02:55 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8442)]do webs_update
Aug 5 04:02:59 kernel: CPU: 3 PID: 4464 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Aug 5 04:02:59 kernel: Hardware name: GTAX11000_PRO (DT)
Aug 5 04:02:59 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Aug 5 04:02:59 kernel: pc : 00000000f724b8e8
Aug 5 04:02:59 kernel: lr : 00000000f724b764
Aug 5 04:02:59 kernel: sp : 00000000ff9872a0
Aug 5 04:02:59 kernel: x12: 00000000f735ac18
Aug 5 04:02:59 kernel: x11: 00000000ff9877ac x10: 000000000023e044
Aug 5 04:02:59 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Aug 5 04:02:59 kernel: x7 : 0000000000000000 x6 : 00000000ff9873e8
Aug 5 04:02:59 kernel: x5 : 0000000000000000 x4 : 00000000ff987de8
Aug 5 04:02:59 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Aug 5 04:02:59 kernel: x1 : 00000000f735ac18 x0 : 0000000000000000
Aug 5 04:02:59 WATCHDOG: [FAUPGRADE][auto_firmware_check:(8510)]could not retrieve firmware information: webs_state_update = 0, webs_state_error = 0, webs_state_dl_error = 0, webs_state_info.len = 0
Aug 5 07:48:26 wlceventd: wlceventd_proc_event(645): eth7: Deauth_ind 28:C2:1F:B1:92:1C, status: 0, reason: Disassociated due to inactivity (4), rssi:-86
Aug 5 13:34:41 rc_service: cfg_server 2907:notify_rc update_nbr
Aug 5 14:19:20 acsd: eth6: COEX: downgraded chanspec 0x1803 to 0x1001: channel 6 used by exiting BSSs
Aug 5 14:34:24 acsd: eth6: COEX: downgraded chanspec 0x1803 to 0x1001: channel 6 used by exiting BSSs
Aug 5 14:49:27 acsd: eth6: COEX: downgraded chanspec 0x1803 to 0x1001: channel 6 used by exiting BSSs
Aug 5 15:04:30 acsd: eth6: COEX: downgraded chanspec 0x1803 to 0x1001: channel 6 used by exiting BSSs
Aug 5 15:19:34 acsd: eth6: COEX: downgraded chanspec 0x1803 to 0x1001: channel 6 used by exiting BSSs
Aug 5 15:34:37 acsd: eth6: COEX: downgraded chanspec 0x1803 to 0x1001: channel 6 used by exiting BSSs
Aug 5 15:46:38 wlceventd: wlceventd_proc_event(685): eth7: Auth , status: Successful (0), rssi:0
Aug 5 15:46:38 wlceventd: wlceventd_proc_event(722): eth7: Assoc , status: Successful (0), rssi:-83
Aug 5 22:20:16 kernel: CPU: 3 PID: 4899 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Aug 5 22:20:16 kernel: Hardware name: GTAX11000_PRO (DT)
Aug 5 22:20:16 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Aug 5 22:20:16 kernel: pc : 00000000f712c8e8
Aug 5 22:20:16 kernel: lr : 00000000f712c764
Aug 5 22:20:16 kernel: sp : 00000000ffbeb090
Aug 5 22:20:16 kernel: x12: 00000000f723bc18
Aug 5 22:20:16 kernel: x11: 00000000ffbeb59c x10: 000000000023e044
Aug 5 22:20:16 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Aug 5 22:20:16 kernel: x7 : 0000000000000000 x6 : 00000000ffbeb1d8
Aug 5 22:20:16 kernel: x5 : 0000000000000000 x4 : 00000000ffbebbd8
Aug 5 22:20:16 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Aug 5 22:20:16 kernel: x1 : 00000000f723bc18 x0 : 0000000000000000
Aug 5 22:20:27 kernel: CPU: 3 PID: 4996 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Aug 5 22:20:27 kernel: Hardware name: GTAX11000_PRO (DT)
Aug 5 22:20:27 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Aug 5 22:20:27 kernel: pc : 00000000f71338e8
Aug 5 22:20:27 kernel: lr : 00000000f7133764
Aug 5 22:20:27 kernel: sp : 00000000ffbea790
Aug 5 22:20:27 kernel: x12: 00000000f7242c18
Aug 5 22:20:27 kernel: x11: 00000000ffbeac9c x10: 000000000023e044
Aug 5 22:20:27 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Aug 5 22:20:27 kernel: x7 : 0000000000000000 x6 : 00000000ffbea8d8
Aug 5 22:20:27 kernel: x5 : 0000000000000000 x4 : 00000000ffbeb2d8
Aug 5 22:20:27 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Aug 5 22:20:27 kernel: x1 : 00000000f7242c18 x0 : 0000000000000000
Aug 5 22:20:55 kernel: CPU: 1 PID: 5177 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Aug 5 22:20:55 kernel: Hardware name: GTAX11000_PRO (DT)
Aug 5 22:20:55 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Aug 5 22:20:55 kernel: pc : 00000000f70158e8
Aug 5 22:20:55 kernel: lr : 00000000f7015764
Aug 5 22:20:55 kernel: sp : 00000000ffccbc00
Aug 5 22:20:55 kernel: x12: 00000000f7124c18
Aug 5 22:20:55 kernel: x11: 00000000ffccc10c x10: 000000000023e044
Aug 5 22:20:55 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Aug 5 22:20:55 kernel: x7 : 0000000000000000 x6 : 00000000ffccbd48
Aug 5 22:20:55 kernel: x5 : 0000000000000000 x4 : 00000000ffccc748
Aug 5 22:20:55 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Aug 5 22:20:55 kernel: x1 : 00000000f7124c18 x0 : 0000000000000000
Aug 5 22:21:09 kernel: CPU: 1 PID: 5265 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Aug 5 22:21:09 kernel: Hardware name: GTAX11000_PRO (DT)
Aug 5 22:21:09 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Aug 5 22:21:09 kernel: pc : 00000000f6f628e8
Aug 5 22:21:09 kernel: lr : 00000000f6f62764
Aug 5 22:21:09 kernel: sp : 00000000ffe861c0
Aug 5 22:21:09 kernel: x12: 00000000f7071c18
Aug 5 22:21:09 kernel: x11: 00000000ffe866cc x10: 000000000023e044
Aug 5 22:21:09 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Report the issue to Asus in the Feedback Form. Nothing else you can do.
It's the firmware_check process that's crashing. That's all that you can tell from the log entries. Most likely to be a software bug.
I was hoping to get answers on what it was and how to fix it before I RMA it.
You may have to go through RMA after every firmware update then. There is always something broken in firmware. Just wait and they’ll fix it, eventually.
