I just bought this router, and was cleaning up my network. First idea was to separate IOT devices from main network. Though I need to be able to access their web ui.
AP Isolation is disabled (tried to enable and disable it again in case of a stuck setting), I tried creating both a normal guest network and the IOT guest network, again isolation disabled and intranet access enabled, same subnet.
But I still cannot ping devices, nor access their web ui.
Should I just give up with the idea of using guest networks, and just put everything into the main one?
Thank you.
Thank you.
