lilstone87
Well I have been considering the AX6000 recently. But I seen info about the AXE16000, which we still have no release date for. Still I think we see it launch soon enough.
I'm honestly curious what's everyones opinion on which one they would get at this point. I do think the AXE16000 could launch costing around $200 more than the AX6000.
The biggest thing for me, will be Merlin supporting it. Which it appears uses the same CPU as the AX6000, he just added support for with his build. So I think there's a good chance he supports it. If ASUS supplies him with this router.
With all that said, which one would most of you pick, if you were looking to buy one of these higher end models in the near future? Biggest thing between the two, AXE16000 obviously will support wifi 6E. Quad band vs AX6000 dual band. Also has two 10gbit LAN ports. I'm curious how these two ports will perform, as it appears both router use the same 2ghz quad core cpu. Ultimately I will only consider this router, if it stays within $200 of the AX6000 at launch.
