OldManBrodie
For a few weeks now, I've been trying to update my GT-AX6000 to the newest firmware version. Every single time, it fails. Whether I do automatic via amtm, automatic through the WebUI, or manual through the WebUI, it fails and reboots back to 3.0.0.4.
After reading up a bit on possible causes, I decided maybe I should try to reset to defaults and try again. I tried resetting via the WebUI and the hard reset method (hold WPS button while powering on). Same outcome.
Ok, maybe I'll flash the stock firmware? Same thing: the update fails and it reboots back to 3.0.0.4.
At this point, I'm ready to burn it all down and start fresh, so I put the router into rescue mode (hold reset while powering up, then go to the basic web interface and upload the firmware). I tried several times. Once with the stock 3.0.0.6 firmware, once with the 3.0.0.6 merlin firmware, and just for funsies, once with the 3.0.0.4 merlin firmware. Each time, I waited about 15 minutes for the router to reboot. When it didn't reboot on its own, I power cycled it. When it rebooted, I couldn't access it. My PC even said that the cable wasn't plugged in. I googled around and found a post on here saying "BE PATIENT, it can take up to an hour for the flash to finish and reboot." So once again I put it into rescue mode, uploaded the 3.0.0.6 firmware, and waited. And waited. And waited some more. I'm currently at over 3 hours since the screen refreshed and said "Update in progress." I've been pinging away at the router, and it hasn't missed a single ping. The ROG LED is fast flashing, and the power LED is blinking super slow (like 5 seconds on, 5 seconds off). To all appearances, it's still working on flashing the firmware. But 3 hours seems excessive. At what point do I give up?
What have I missed, screwed up, not tried, etc? People say it's super hard to brick these routers, and while it seems like I can reliably get into rescue mode, I can get no further. Is this router toast?
