Hello,
I have a axe16000, Merlin 3006... lastest installed.
I have created a guest vlan (52) on wifi. and the intranet wifi (no change vlan1)
both is working fine on the asus router. (if connected to "52" wifi, receive ip 192.168.52.xx and to "1" ip 192.168.1.xx)
now I want to extend the wifi in house and outside.
For this I have a ubiquiti LR6 AP, ubiquiti switch. ( I have also try with Juniper and netgear managed switch)
I have the unifi controler as software on one laptop to configure the switch and APs.
On the unifi I have configure the same wifis as on the asus. (wifi, vlans, no dhcp)
The unifi AP is connected wired to the switch and then to port 4 on the asus.
On unifi, vlan52 is tagged, and vlan1 untagged.
On asus, the port ist on "standard" all allowed ("all default")
If I connect a device to wifi1, on the unifiAP it works fine, device receive ip from asus, all is working.
If I connect a device to wifi52, connecting do not work, unifi say "DHCP timeout"
If I connect first to wifi52 on the asus, and move the device near the unifiAP, roaming will work, the device connect to the unifiAP and it works, a time long...
I have try, to set the port on the aus to "trunk" and "access" but then I lose the main wifi1, (by "access" the wifi52 is working, but no wifi1)
I have also try by using a juniper switch, on the juniper I have set up a dhcp server for vlan52, so if a device connect to unifiap on wifi52, they receive a ip adress.
But the still no connection to the internet..
On the unifi switch I need to connect some APs, and some Computers (vlan1)
Do somebody have a ideaa, why the vlan52 not work by eth port when configured as "all(default)" ?
