Guest only 2.4 GHz wireless RT-AC56?
jea101
I would like to enable a 2.4 GHz guest network with no Intranet access. However, if the 2.4 GHz radio is enabled the unrestricted 2.4 GHz network is also enabled. Is there any way to allow guest but disable the unrestricted 2.4 GHz network?
Everything I normally use wirelessly is 5Ghz
CLI command in a script startup would be OK.
