Guest wifi network - manage devices from the LAN
Carlos M.
I build a guest wifi network just for IP cameras. My idea is to add the cameras to the Parental control and block the trafic to internet. This works fine at the moment. The other desire is block the access from this guest network to the LAN. Works perfect aswell. The problem happens when I need to manage the GUI interface at the port 80 from my LAN. If I try reach a camera from a laptop in my LAN, I can't access to the IP caamera GUI.
Any idea about how can I bypass the restriction from my LAN?
Thanks in advance.
Hi, how can I bypass it?
What you suggesting is not really the purpose of a Guest network. After all, a Guest network is for computers you don't trust. However, this will show you how. Judicious use of ARP broadcast and ARP reply is what you need. No need to flood the network with unnecessary ARP traffic or create security holes, so we purposely specify every interface and device argument in the ebtables rules. Example:
/jffs/scripts/firewall-start
#!/bin/sh
# Allow ARP broadcast from a specific IP address on the 2.4GHz Primary Wi-Fi interface to all devices on the 2.4GHz Guest Wi-Fi interface
/usr/sbin/ebtables -t filter -I FORWARD -i eth1 -o wl0.1 -p ARP --arp-ip-src 192.168.1.111 -d ff:ff:ff:ff:ff:ff -j ACCEPT
# Allow ARP reply from a specific MAC address on the 2.4GHz Guest Wi-Fi interface to a specific IP address on the 2.4GHz Primary Wi-Fi interface
/usr/sbin/ebtables -t filter -I FORWARD -i wl0.1 -o eth1 -p ARP -s 00:35:5A:12:13:14 --arp-ip-dst 192.168.1.111 -j ACCEPT
  • vlan1 is the Ethernet LAN Ports interface
  • eth1 is the 2.4GHz Primary Wi-Fi interface
  • eth2 is the 5GHz Primary Wi-Fi interface
  • wl0.1 is the 2.4GHz Guest #1 Wi-Fi interface
  • wl1.1 is the 5GHz Guest #1 Wi-Fi interface
  • wl0.2 is the 2.4GHz Guest #2 Wi-Fi interface
  • wl1.2 is the 5GHz Guest #2 Wi-Fi interface
  • wl0.3 is the 2.4GHz Guest #3 Wi-Fi interface
  • wl1.3 is the 5GHz Guest #3 Wi-Fi interface
  • eth0 is the WAN interface
  • 192.168.1.111 is the IP address of your computer
  • 00:35:5A:12:13:14 is the MAC address of your IP camera
  • ff:ff:ff:ff:ff:ff is for broadcasting to all devices on an interface
Wow, sounds great... and complex for me :( I'll try to add the script with the adapted code inside but... what you mean with "is not really the purpose of a Guest network" I had this solved with Tomato and the virtual wifi networks so... I thought could be the same function.
If I put all the cameras together into the same network I'l have the control of this devices under "one button" and switch off the wifi or the internet access remotelly if I need it.
I was just saying that you're not really supposed to be doing it. However, I think you have a good enough reason to do it, and I think you're on the right track.
