Hacked asus ax-6000 - Webui access locked
francisport
Hi guys,
I have an ASUS ROG GT AX-6000 running the official latest firmware. No access is granted outside internal lan, ddns is enabled and openvpn+wiregard vpn were active.
2 weeks ago I've detected that my Webui access didn't work, but luckily I have ssh-keys still operational. I did a research here how I could reset my http access, and I found: nvram set http_password=admin might help but also I detected that nvram save/commit commands didn't work either.... Something was really strange. No logs since the day before.
I reboot the router and this time nvram command worked, so I thought I was a lucky clever guy restoring Webui access..... however, the day after, Webui was locked again!! but this time nvram set http_password=admin didn't work at all, the variable was there, save/commit work also but without any effect. I started a long journey to recover it but lot of problems, never had such amount of "misfortune"
Restore from fabric didn't work --> webui was still locked and now without my ssh-keys but finally, after a long journey I could restore it.
But something I want to share in case someone could validate or help; below is a bunch of nvram variables I've never seen and I think they should not be there:
1:dot11agofdmhrbw202gpo=0x1000
2:pa5g160a0=0x27c7,0xb2c3,0x0000,0x168b,0x27c7,0xb2c3,0x0000,0x168b,0x26e5,0xb2f1,0xffff,0x1066,0x2671,0xb805,0xff2b,0x1d62
2:pa5g160a1=0x2cef,0xa9bc,0xffff,0x183d,0x2cef,0xa9bc,0xffff,0x183d,0x2ccd,0xa85b,0x0000,0x0f91,0x2b14,0xb03b,0xfcf8,0x091
2:pa5g160a2=0x28b6,0xb1ff,0x0000,0x13f0,0x28b6,0xb1ff,0x0000,0x13f0,0x27ca,0xb287,0x0000,0x10e5,0x2646,0xb872,0xfe5d,0x1be8
2:pa5g160a3=0x2734,0xb4cc,0x0000,0x1b83,0x2734,0xb4cc,0x0000,0x1b83,0x264d,0xb431,0x0000,0x112b,0x261e,0xb756,0xff85,0x17aa
2:pa5g40a0=0x2730,0xb372,0xff0e,0x0000,0x276d,0xb131,0x0000,0x0000,0x266a,0xb261,0x0000,0x0000,0x25e7,0xb2f2,0x0000,0x02a3,0x2590,0xb
436,0x0000,0x003d
2:pa5g40a1=0x2c7d,0xa949,0x0000,0x0dc3,0x2c74,0xa8fb,0x0000,0x0d28,0x2c01,0xa906,0x0000,0x07cc,0x2b81,0xa994,0xff9c,0x0000,0x2b56,0xa
881,0x0000,0x0000
2:pa5g40a2=0x27bb,0xb2b6,0x0000,0x0ba0,0x279d,0xb2c5,0x0000,0x0934,0x26ad,0xb443,0x0000,0x0c10,0x2640,0xb3f8,0x0000,0x067b,0x2608,0xb
367,0x0000,0x0025
2:pa5g40a3=0x2652,0xb591,0x0000,0x1238,0x26a5,0xb46a,0x0000,0x0ce4,0x2586,0xb4aa,0x0000,0x0658,0x24f0,0xb5b8,0x0000,0x09df,0x2447,0xb
86c,0xffff,0x1157
2:maxp5gb0a0=0x6E
2:maxp5gb0a1=0x6E
2:maxp5gb0a2=0x6E
2:maxp5gb0a3=0x6E
2:maxp5gb4a1=0x6E
2:mcsbw205ghpo=0xBA976420
2:mcsbw205glpo=0xBA976420
2:mcsbw205gmpo=0xBA976420
2:mcsbw205gx1po=0xBA976420
2:mcsbw205gx2po=0xBA976420
chilli_authport=http
chilli_protocol=http
It's quite sure that someone has hacked it, and now I have doubts that those nvram variables should be there. Any idea how to compare or validate if those nvram variables are really needed?
FrancisP
Did you, or have you in the past, enabled AiCloud (or its subfeatures) on the router? If so see the following discussion:
There were several users in later posts of that Malware discussion who were helping people recover their routers affected by that specific malware.
436,0x0000,0x003d
881,0x0000,0x0000
367,0x0000,0x0025
86c,0xffff,0x1157
2:maxp5gb0a0=0x6E
2:maxp5gb0a1=0x6E
2:maxp5gb0a2=0x6E
2:maxp5gb0a3=0x6E
2:maxp5gb4a1=0x6E
Those are all perfectly normal variables for your model of router.
