Hard Drive invalid files
usamario
Hi
How can I get rid of 3 files in my hard drive that look like this:
ntfsck.00000005 ? Other than removing and reformat the drive.
I used to be able to this many years ago using ssh or Telnet, I just don’t remember the steps or commands, “getting old is not for sissies”.
One more question: is there a way to rename my drive from Asus-Merlin firmware, I am running 380.66.6?
Thank you
Mario
Hi
Thank you
Mario
Don't know about the ntfsck thing, but the label can be changed trough SSH, look under Label the Partition here:
http://www.algissalys.com/how-to/format-and-partition-usb-asuswrt-routers
Hi
I stopped the drive via the browser, plugged the usb cable in my pc and remove the bad links and rename the drive, plugged it back to the router and apparently it worked.
Mario
