Hardware question - keep or recycle?
JaimeZX
I'm getting ready to move. My old AC3100 doesn't seem to boot far enough to issue an IP address so I can SSH in / get a GUI. Are there any options for some kind of OS access prior to that stage, or is this thing bricked? (Like, I think some routers have a serial port inside the case / not normally accessible...)
Thanks!
I swear I tried that before, but I did it again just now and it MAY have worked. All LEDs are off but I can access the GUI and mess around with it. Dunno. More to follow. :)
Once you get in do a factory reset, with the WPS reset if possible, do a minimum setup and flash the firmware again.
