Help configuring Network Services Filter to stop all internet access
subie
Hello,
I would like to stop all internet access on a computer but I want it to be accessible to the local network. the simplest way I can do this is to seperate the computer by using 2 routers, but I found this Network Services Filter which might work while searching for a way to use only 1 router.
I like no inbound and outbound traffic from the internet to go to this computer but allow all local network computer to access the computer. How should i set it up?
Should I put "*" to the port?
Here is the feature
https://event.asus.com/2012/nw/dummy_ui/en/Advanced_Firewall_Content.html
Thank you!
You just enter the IP address of the PC in the "Source IP" box and leave the others empty. Create one rule for TCP and another for UDP.
As I alluded to in your other thread, if the PC has no internet access how will you keep it up to date with patches and anti-virus?
Thank you ColinTaylor! I will try that!
I will update it manually using WSUS offline update.
