Hi migueln, Cloud200 has already given you several good references. In version 1.4.0 there is a basic SOHO wizard that should get you up and going quickly. If you have further question please ask them on community.ubnt.com forum.Please help on a edgemax poe router, I thought imknew something about networkin butnobviously I dont please help me configure this thing, I am really confused on everything!
Did you post on ubnt's forum? I don't recall seeing a post.What I want is dual wan
firewall enabled and I will tell you with ports are required, pptp server, openvpn setup, dyndns setup one dhcp and every other port only part of the dchp config as a switch, so basically that is all I need.
best regards.
MN.
Thread starter | Title | Forum | Replies | Date |
W | I need some help with a new router and network card | Routers | 12 | |
C | Help me identify device - ARM, BCM4708, BCM4366, ASUS, LINKSYS, OR ??? | Routers | 3 |
Welcome To SNBForums
