Help Connecting Node
fotingo
I have an AX88U Pro on the latest version 3006.102.6 and I also have an AC86U and would like to use it as a node to extend my wifi signal.
I am not able to make the node connect at all. I have tried using an Ethernet cable, also via wireless and placing the routers next to each other. It just won't connect.
Is this because of the firmware version difference?
I have reset the AC86U multiple times and start the setup over as a Node, but it just won't connect to the main router.
Any ideas?
Thank you
