Help me pick a router!
Phasio
Hello everyone,
I've been looking at routers for the past 2-3 days, and I figured someone here might be able to give me some advise!
My needs:
1. My cable speeds are 100/100 .. So it's quite a fast connection, and I'll need a router that has allows me to have an ethernet connection that fully takes advantage of it.
2. A wireless connection. It does not have to able to take fully advantage of the connection, but I'd like for it to be quite reliable (hate rebooting routers) and with a somewhat decent range. I don't care if it's 2,4 ghz or 5 :)
3. As cheap as possible!
Is gigabit recommendable?
So far I've looked at these two:
1. Wireless-N150 High Power Router & Access Point
2. TP-Link TL-WR1043ND
Thanks in advance :)
Kind regards,
The Dane!
Use the Router Charts to find routers with WAN to LAN and LAN to WAN speed > 100 Mbps.
Gigabit is helpful only if you have devices with Gigabit LAN ports.
Cheap and reliable don't necessarily go together.
