help with openvpn policy rules
dawg1
i have 2 vpn´s set up on my asus merlin router. client 1 is windscribe and client 4 is ivacy. i have both setups the same with a policy rule to route the traffic through a particular IP/VM XP computer. I have tested each one being on individually and both show connected in the asus vpn section and log. BUT I can only get the internet working on the policy IP when using client 1, windscribe VPN. If I switch it off and use client 4, ivacy, the target PC does not get internet. What could be wrong?
Do you have the KILL-switch enabled for VPN Client 1?
Use
ip rule
to display the state of the Selective Routing RPDB rules, when it is/not working to identify any rule conflicts.
Do you use same port on both clients? Have to use different ports.
Have you killswitch on on both clients?
There’s also this from Merlin.
https://github.com/RMerl/asuswrt-merlin/wiki/Policy-based-routing
