Help with port forwarding
froggy666uk
I installed Merlin 384.13 yesterday on my AC86u and did a factory reset.
Prior to to the reset I had a port forward set up so that I could connect to one of my internal devices on port 922 from the internet - worked fine. After the factory reset I don't seem to be able to get it working again.
Does the attached look ok? Have I missed something else that I need to configure?
I can confirm 192.168.1.13 is up and running and I can connect on port 22 from my lan.
Any help gratefully received:)
Cheers,
Dave.
Try giving it a Service Name. Perhaps it doesn't like it being blank.
Check the status of the port forward under System Log - Port Forwarding.
Also check your WAN IP address hasn't changed.
Hi Colin,
Thanks for the reply. I've given the service a name, same issue. Screenshot of the system log page attached (I'd set the protocol to TCP in this case, if I set the protocol to both it shows 2 entries, one for TCP and one for UDP).
I have a static IP address from my provider, and I've confirmed this is set correctly in the network map.
I notice the Port Forwarding log page shows a chain of 'VSERVER' - is that an iptables chain? Are there any iptables commands I can run to verify all is set correctly?
Cheers,
Dave.
Yes, VSERVER is the port forwarding chain.
The following command should verify the rules:
iptables -L -vnt nat
admin@RT-AC86U-4C20:/rom/etc/init.d# iptables -L -vnt nat
Chain PREROUTING (policy ACCEPT 2147 packets, 300K bytes)
 pkts bytes target     prot opt in     out     source               destination
  448 46219 VSERVER    all  --  *      *       0.0.0.0/0            80.229.25.xxx
    0     0 VSERVER    all  --  *      *       0.0.0.0/0            169.254.114.58
Chain INPUT (policy ACCEPT 1258 packets, 143K bytes)
Chain OUTPUT (policy ACCEPT 780 packets, 63135 bytes)
Chain POSTROUTING (policy ACCEPT 758 packets, 59395 bytes)
    0     0 ACCEPT     all  --  *      *       192.168.1.0/24       0.0.0.0/0            policy match dir out pol ipsec
  867  139K PUPNP      all  --  *      ppp0    0.0.0.0/0            0.0.0.0/0
  447  111K MASQUERADE  all  --  *      ppp0   !80.229.25.xxx        0.0.0.0/0
    0     0 MASQUERADE  all  --  *      eth0   !169.254.114.58       0.0.0.0/0
   23  3792 MASQUERADE  all  --  *      br0     192.168.1.0/24       192.168.1.0/24
Chain DNSFILTER (0 references)
Chain LOCALSRV (0 references)
Chain PCREDIRECT (0 references)
Chain PUPNP (1 references)
Chain VSERVER (2 references)
    1    52 DNAT       tcp  --  *      *       0.0.0.0/0            0.0.0.0/0            tcp dpt:922 to:192.168.1.13:22
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:922 to:192.168.1.13:22
  447 46167 VUPNP      all  --  *      *       0.0.0.0/0            0.0.0.0/0
Chain VUPNP (1 references)
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:9308 to:192.168.1.113:9308
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:47214 to:192.168.1.38:47214
    0     0 DNAT       udp  --  *      *       0.0.0.0/0            0.0.0.0/0            udp dpt:45795 to:192.168.1.38:45795
Thanks. Look ok? Not sure what that 169.254.114.58 address is!
That looks OK as far as I can tell.
It looks like you're using PPPoE, that's not a connection type that I'm particularly familiar with. But I expect 169.254.114.58 is the local connection to your modem and 80.229.25.xxx is your public IP address that is tunnelled across PPPoE.
The only notable thing I can see it the DNAT line for port 922. It has actually received one packet which suggests to me that the port forwarding is working. I would check the firewall settings on the target PC.
Ah good spot! I've tried hitting the external IP/port a couple of times and I can see the packet count increments each team, so looks like the port forwarding rule is working.
Dunno why I still can't get through then:) It is just a raspberry pi sitting on my lan, no firewall running. I can connect on port 22 from my router:
admin@RT-AC86U-xxxx:/tmp/home/root# telnet 192.168.1.13 22
SSH-2.0-OpenSSH_7.4p1 Raspbian-10+deb9u6
Protocol mismatch.
Connection closed by foreign host
Prior to doing the factory reset were you using a different IP address range for your LAN?
All sorted - thanks for pointing me in the right direction! Before I did the factory reset my router had an IP of 192.168.1.254, I left it as the default 192.168.1.1 after the reset, but forgot to update any devices with static network settings.
Thanks again:)
