Help With This Log Message
OKLY
Hi all, I need help understanding this message. I was previously on an AC56U with 380.70 and did not encounter this message in my logs until I changed to an AC86U with 384.60 today.
Jul 26 18:20:15 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 18:20:17 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 18:24:41 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 18:24:42 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 18:25:50 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 18:25:52 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 18:56:59 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 18:57:01 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 19:37:35 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 19:37:36 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 19:46:53 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 19:46:54 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 19:52:00 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 19:52:02 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 19:53:53 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 19:53:59 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Jul 26 19:54:30 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Jul 26 19:54:32 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
This message has been reported a lot recently. Search the forums to see if there is an answer that applies to you.
Could be a flaky device plugged into your router. Check the cable and the device plugged into port 0. Sometimes these occur when a device powers down during powersave and comes up. What devices do you have plugged directly into the router?
When you mention powersave, suddenly it makes sense. It is actually a powerline ethernet adapter to wire another device from another room to the router. I guess the adapter has some powersave mode.
