I'm fairly new to the powerline ethernet stuff. But I have researched it online and decided it was the best method to get internet access to my shop outbuilding. The outbuilding has 220 and 110V ran from the house panel through buried conduit (two 90A legs) and it worked fine at first with two Cisco/Linksys PLE400 adapters. I'm about 150' away from the house and I was getting decent internet speed and connectivity. Then the other night we had some rain and that next morning I started to loose the connection between the two adapters. I reset them a few times and eventually they would no longer link up. I can't imagine and moisture in the conduit causing a problem otherwise I'd have breakers tripping and a short circuit of some sort.
So I ran an extension cord from the house out to the shop and I'm working off of it for now. My thought is to run an isolated circuit (dedicated 110V) out here through the conduit. I would pull some ethernet cable through, but from I understand you can't even use CAT6E shielded cable without interference being so close to the power lines.
Any thoughts on what might be causing the issue before I spend the money and time on running an dedicated line?
Thanks!
Thanks!
