How can i add and Ip address whitelist in skynet?
Furio
Hello,
I installed Transimion in my router with diversion and skynet, but when i try to conect to trasmsion is not possible.
This is the error message show in browser
403: Forbidden
Unauthorized IP Address.
Either disable the IP address whitelist or add your address to it.
If you're editing settings.json, see the 'rpc-whitelist' and 'rpc-whitelist-enabled' entries.
If you're still using ACLs, use a whitelist instead. See the transmission-daemon manpage for details.
How can i add this Ip to whitelist in Skynet?
192.168.1.1:9091
Thanks for your help, sorry if it is a silly question but i am noob.
Hello,
403: Forbidden
192.168.1.1:9091
I think you would be better off if you asked or moved your question to the skynet thread. I'm not shirking from answering it though, just that I'm a noob too. I've always ran skynet stock, haven't had a need yet that I'm aware of to whitelist anything additional.
However, I think your address you're wanting to whitelist is a local ip for your router.
jts
RT-AC86U w/ 384.17, RT-AC68U Aimesh node w/ same, Diversion, UiDivstats, Skynet, AiProtection, DoT, Scribe, UiScribe, Conmon, SpdMerlin, ScMerlin, Nsrum, NtpMerlin, OpenVPN selective clients
How do you know Skynet is blocking anything?
Not yet, August 29th in an alternate universe near you. :)
I was making some test and as you said Skynet is not the problem.
The solution is in "settings.json" archive leave "rpc-whitelist-enabled" as "false" and should work from any ip.
Now is working, thanks for you help
