How can I overwrite the CFE partition?
lenovomen
Hi everyone,
I have an ASUS TUF-AX3000 V2 router (RT-AX58U V2 hardware) running GnuTon firmware (3006.102.3_1-gnuton1). I want to completely wipe and rewrite the router to make it like it just came out of the factory, including the CFE and all partitions (NVRAM, JFFS, linux) to ensure no malware (e.g., Cyclops Blink) remains. I understand that a standard factory reset and TFTP only partially wipe, leaving the partition table and CFE intact. Is there a way to update the CFE or rewrite the partition table at home? I’ve already tried factory reset and JFFS formatting, but I’m concerned about deeper-level backdoors persisting. If JTAG/serial console is needed, what tools do you recommend? Or is recovery mode with stock ASUS firmware reinstall enough? Any experiences, step-by-step guides, or warnings would be greatly appreciated.
Thanks!
