How do I access a UeeVii CPE5.8G's GUI to change the SSID and Password?
johnnieq
I have followed the instructions from the User Manual, and tried what others have posted on YouTube, but nothing seems to work.
The manual says you must edit your Network settings to access the Bridge GUI.
From UeeVii Manual
Open - Network & Internet
Edit - Network Properties
Change from - Automatic (DHCP) to Manual
Set IP Address - 192.168.255.2
Subnet Mask - 255.255.255.0
Gateway - 192.168.255.2
Preferred DNS - 192.168.255.2
Alternate DNS -
I have tried the above settings and several more, but all fail to Save.
Has anyone been able to do this? If so, how?
From UeeVii Manual
Alternate DNS -
I am here! DM for help details, thanks!
From UeeVii Manual
Alternate DNS -
Hi John - did you get his sorted? i have the same problem. do you have any advise please
Yes, we help him out with the configuration settings. Anyway, you can DM me for details :)
How to Access and Setting the Wireless Bridge CPE Through Computer Access:
Step 1. Use a PoE adapter to power the wireless bridge through a network cable. Pay attention to the "PoE" and "LAN" ports marked on the PoE adapter, and power is supplied by POE instead of a DC power interface.
Step 2. Use a network cable to connect the CPE "LAN" port, connect the network cable to other ends to the PoE Adapter "POE" port, use another network cable to connect to the "LAN" port of the PoE adapter, and connect the other end of the network cable to the computer's "LAN" port.
Step 3. Find the number of the Wireless Bridge CPE digital display tube. For example, if the number is 1 and the CEP is the A master bridge, then the IP of this CPE is 192.168.255.101; if the CPE is the B slave bridge, then the IP address of the CPE is 192.168.255.201. (There is a table corresponding to a number and IP in the manual)
Step 4. Crucial step: Modify your computer's IP address, change your computer's IP address to 192.168.255.xxx(192.168.255.xxx cannot be the same as the IP of the CPE), make your computer's IP and the bridge's IP address be on the same network segment so that you can access them. Please refer to the manual to modify the computer IP address step or Google searches how to modify the computer IP address, it is simple.
Step 5. After you modify your computer's IP address, you open the computer browser and enter the IP address of the wireless bridge to access it. For example, enter 192.168.255.101 to access.
Step 6. Enter the account password "admin/admin" to access, and set it after successful access.
