talisman2208
I'm confused at how it even got named that, as it's a wired network. I have the ASUS ZenWiFi Pro AXE 11000's
Any ideas? I don't see any options in the settings.
Its a Windows thing for LAN connections. Search the internet for how to change "network profile name" on Windows. Example:Any ideas? I don't see any options in the settings.
In the second Windows 11 example they are renaming the network adapter name, not the network name. It is the only the first example that I'm aware of that changes the network name.Its a Windows thing for LAN connections. Search the internet for how to change "network profile name" on Windows. Example:
How to Change or Rename the Active Network Profile Name in Windows 10
Windows 10 automatically creates a network profile when you connect to a network.www.howtogeek.com
How to Change a Network Name in Windows 11
Changing a network's name in Windows 11 lets you refer to it with a custom name instead of the one provided by Windows. Here are three methods.www.lifewire.com
Yeah took a second read through the Win 11 article and the writer seems to use "network name" and "network adapter name" interchangeable. Removed that link from my earlier post.In the second Windows 11 example they are renaming the network adapter name, not the network name. It is the only the first example that I'm aware of that changes the network name.
| Thread starter | Title | Forum | Replies | Date |
| A | ZenWiFi Pro ET12 dns change problem | ASUS Wi-Fi | 6 | |
| C | WiFi extender always showing as wired | ASUS Wi-Fi | 2 | |
| J | AI Mesh not showing wired devices | ASUS Wi-Fi | 1 |
Welcome To SNBForums
