Hello,
I’m currently running a solid mesh setup with three RT‑AX86Us, covering a 6,600 sq ft lot (the house itself is 2,500 sq ft). The coverage is flawless with zero dead zones, and the AX86U units continue to perform exceptionally well. They can run 8–9 months without a reboot, unless I update the firmware.
My nephew is moving into his newly purchased home, and I’m trying to help him choose a reliable router setup. My first thought was to recommend the RT‑AX86U, since it has been incredibly stable for both Wi‑Fi and Ethernet in my experience.
However, the AX86U is getting older, so I’m wondering if it might be time to move up to something in the BE series, such as the RT‑BE86U, possibly paired with either an AX86U or another BE86U as a mesh node. Wi‑Fi 7 isn’t a requirement — Wi‑Fi 6 performance is perfectly fine for his needs.
My questions:
Any advice would be appreciated.
My questions:
- How reliable and stable is the RT‑BE86U (Wi‑Fi and Ethernet) compared to the AX86U? The AX86U has been extremely dependable for me, so I’m curious whether the BE86U can match that level of stability.
- Would it be better for my nephew to use the RT‑AX86U Pro with an AX86U as the mesh node instead?
