How to add VPN to ASUS RT-BE88U router with Private-Internet-Access (PIA) subscription?
Papbear77
Hi all,
I recently purchased a PIA VPN subscription and while it has been great while using it on standalone devices, I would like to make the VPN "permanent" on the router RT-BE88U itself as I understand that all devices would then be "VPN"ed via the router without having to install the VPN app on each device separately.
I have read the documentation on ASUS-website (and the "how to" links on the router) on this but am not-tech savvy enough or do not know enough or where to get the information from, or to understand how to "activate" or "install" the VPN on the router (maybe all!). Further, I cannot find PIA VPN listed on the VPN list so am lost as to which one do I use or can use as a proxy?
The part where there are tabs related to "VPN Server" and "VPN-Fusion" got me confused. Where do I input the details of my PIA-VPN subscription to utilise the VPN on the router? Which of these "VPN servers" can I use?
Grateful for any advice or links to the correct documentation for this and much apologies for the noob question ....
You are configuring a client, so it must be under VPN Fusion. Your provider uses the OpenVPN protocol.
