How to best migrate from AX86U to BE86U?
Jeje2
Just got the Asus RT-BE86U to replace our RT-AX86U unit.
What would be the best / easiest way to move settings over to the new router?
The best way is to add them manually. While the easiest method is to save the config file from the RT-AX86U and upload it to the RT-BE86U, but I think it would cause problems and really not recommend doing it.
The best thing would be to save a buck and get an AX86U Pro. Then set it up manually. Using a settings file from another model router is a great way to brick a new router!
Be honest...do you really need WIFI 7?
Confession: I just ordered a 2024, unlocked, 5G mobile phone with Wi-Fi 5/ac 2.4/5.0 and one antenna... max 5.0 link rate of 433Mbps with WPA2 security. Sort of goes against the grain around here! :)
I hemmed and hawed about it and finally decided I will get my usage out of it ($400, on sale for $237). The rest of its specs are plenty good for my usage, but it was not easy to overlook its lagging wireless support. I figure if it works near term, I'll get my money's worth out of it and then some; I intend to use it for years (ships with Android 14; will get Android 15).
It will have no cellular voice service... just a Google Fi data-only SIM off my wife's account and my choice of softphone and ITSP. Been doing this for years already with hand-me-down phones.
I suspect the 2025 model will update the wireless spec, but I could not wait... my current hand-me-down (Wi-Fi 3/g 2.4 only) is from 2016 and near its end.
Do I really need Wi-Fi 6/ax? :)
OE
I'll get a Wi-Fi 7 router in 2025/2025, well, maybe, or when the RT-AX86U fails eventually after 6 years or so...
Can't be more than $200 though.
Asus sells BE models in China under $100 right now. Competing with TP-Link and Xiaomi.
I may be mistaken but often the China versions lack VPN capabilities.
Asus firmware release is global. Many China region Asus routers actually have extra features not available in other regions plus many East Asia models have region change options in settings. All included in the firmware for your routers, but hidden in your region. While we are not allowed here to comment "illegal" firmware forks (and conversions not while ago), in China modified firmware is readily available for multiple Asus models with included app store in GUI. This firmware becomes available shortly after official release, much faster then our 3rd party firmware. Suspiciously fast... like Asus is helping in the process fast. Not surprised, quite possible - business interests, one of the largest markets just next door.
Entry-level RT-BE3600 is around $70 in China and $200 in the US.
…..This firmware becomes available shortly after official release, much faster then our 3rd party firmware. …
I’m going to have to take your word for that :)
Both versions are often offered here, with the China versions being cheaper, although nowhere in the proportions cheaper than your example above, with the limitations of the original FW understood to be the reason for the lower cost.
The average user, i.e. those who probably don’t bother with 3rd party FW but might consider a built in VPN, would probably be the target audience for my comment above about the lack of VPN.
Someone reported RT-BE6500 for ~$110 in China. At this time when I checked RT-BE3600 was around ~$70. This is a totally different market with many local players offering low price products. I far as I know 6GHz spectrum is allocated to telecom operators in China and unavailable for Wi-Fi at the moment. Whatever is marketed as Wi-Fi 7 is dual-band. I browse some Chinese places for tech info from time to time and the folks were discussing some Xiaomi/Huawei local models starting from ~$60. Searching for such models on global websites shows no results - local market only products.
Anyway, can't have it here in CA/US or in the EU at this price point. 🤷‍♂️
I just ordered the RT-BE86U and will get it in 2-3 days.
Planning to do an upgrade by just saving the config backup from the RT-AX86U and upload it to the RT-BE86U once it's updated to the latest Merlin firmware.
Will see how much is missing or additionally needs to be set up afterwards due to some new features.
I'm also planning to set up an separate IoT Wifi for my IoT devices, as this function is not included in the RT-AX86U (non pro modell).
P.S. Bought the RT-BE86U for the same price as they sell the RT-AX86U pro here in Sweden. (special Christmas discount at one online store)
Going from same model to same model is a problem. You want a shortcut going between AX to BE class router?
Let us know if it goes, problem free.
After you've had enough troubleshooting, Hard Reset the firmware and configure the new router from scratch. :)
OE
This may work well with stock Asuswrt only, not guaranteed with Asuswrt-Merlin. Save/Restore is Asuswrt tool.
Unfortunately, the RT-BE86U software is not yet perfect, my previous RT-AX86U worked much better, the software was more stable and had more options (e.g. in AiCloud 2.0)
Just to give you all an update.
I did a manual new configuration of the new RT-BE86U once I got it.
Once the router was online, I directly upgraded it to the latest Merlin firmware 3006.102.2_2 and rebooted the router. Then I started configuring everything from zero.
Strangely, I couldn't re-use my old primary Wifi password, it had 64 digits and a special sign ";" or "<" which was not approved to be used in the RT-BE86U. So I had to set a new password, and then reconfigure all to the main Wifi connected devices at my home.
A bit painful, but i fixed that during one evening.
Then I set up the IoT Wifi, and configured my IoT devices to connect to this one, additionally as I was creating my Guest Wifi with the same password I had before. (that was OK to use)
Afterwards, i opened SSH to the LAN and installed NextDNS to the router to be used as my DNS service.
Additionally enabling QoS and changing the priority (Streaming first, Gaming second), and enabling QoS - WAN/LAN Bandwidth Monitor - Apps analysis.
The last thing I did today (3 days later), was to reconfigure my WireGuard VPN Server and exporting the new profiles for all clients, in addition to take out an DDNS name from ASUS and activate DDNS.
I read previously that people are recommending to wait with an upgrade to the RT-BE86U, as it still has a couple of bugs. So far, my router is running stables since the start, but I found the following Issue:
When this is enabled, this feature does not detect all apps as on the RT-AX86U. No Steam traffic detected, not Netflix and other streaming services detected by this service.
The main app categories that are shown are
  • General
  • TLS/SSL
  • HTTP
Looks like this function is not yet implemented correctly in this new model router.
/Geraner
Rebooting the router is insufficient, you are supposed to do a "factory reset" (from GUI) after the switch from factory to RMerlin.
If you run into problems, you will know what to do next.
