Help RT-BE86U with Pi-Hole
mac138
I have upgraded my router from AX86U to BE86U. I have no end of issues getting it work. I took screens shots of previous router config. Expected it work.
I think the router not fit for purpose!
The following setting worked with my AX86U
  1. Skynet blocking Home Assistance, remove skynet and gone back to stock firmware for HA to work
  2. DDNS would not work in Synology Nas, I have changed the DNS IP from Pi-hole to Router IP (192.168.0.1).
  3. PI Hole (unbound installed) no longer work following thhttps://www.asus.com/support/faq/1046062/
    • Asus BE86U >Lan >DNS Service 1 192.168.0.3 (PI-hole address) other Asus router in mesh network no longer connect to internet unless leave it blank ) I get internet via wired to connection to the router from PC?
    • changed this from 192.168.0.3, 1.11.1 to 1.1.1.1.8.8.8.8
    • Original AX86 configuration worked previously
    • Please advise, I been on this for days trying to get all devices working as before.
What router firmware are you using now?
The RPI needs to have a static Ip address not a Manually Assigned address in the router.
The WAN DNS Server settings needs to be set to the IP address of the same provider. For example: 1.1.1.1 and 1.0.0.1 or 9.9.9.9 and 149.112.112.112 or 8.8.8.8 and 8.8.4.4.
The Pi-Hole IP address should only be in the LAN/DNS Server 1 or 2.
RPI has static IP set in the setting also in Manually Assigned IP around the DHCP list.
Firmware Manually 3.0.0.6.102_39125-gf4f9993_1473-gab123_BB0B
WAN DNS Server 1.0.0.1 or 9.9.9.9 and 149.112.112.112 or 8.8.8.8 and 8.8.4.4.
The Pi-Hole IP address should only be in the LAN/DNS Server 1 or 2. This worked in my AX86 router nor current BE86U
In my case I have set DNS in LAN settings to 192.168.1.5 where my pi-hole is installed. I also have manually assigned 192.168.1.5 in the "Manually Assigned IP around the DHCP list". In DNS Director I have set DNS Director enabled and Global Redirection to User Defined 1 and in the User defined DNS 1 IPv4 section I have set 192.168.1.5.
I think I have fixed the issue. I have put the router back factory default started again. setting the Lan DNS service to pi-hole 1st and building upon this. I reckon the original config was corrupted. As I seen odd behaviour, network not working.
