How to compile from source asus merlin.
Noctharion
Hello,
I’m trying to compile Asuswrt-Merlin directly from source for the RT-AX88U Pro, but I can’t get it to build successfully, even after following all the steps from the wiki.
The reason I need to compile is because I want to modify the LAN IPTV mode.
Currently, when I set my ISP’s VLAN for the IPTV box, the box only receives traffic from that VLAN. However, the new set-top boxes also require Internet access – it can’t be restricted to VLAN traffic only.
I’ve already located the part of the code where I need to make the changes, but since I can’t get the firmware to compile, I’m stuck.
Could someone please give me some tips or guidance on how to properly compile the firmware for the RT-AX88U Pro, or point me to any additional documentation that might help?
Thanks in advance!
@Noctharion, there are general directions on how to compile from source posted on the Asus-Merlin GitHub wiki page....
PS: Also, see the search feature if you haven't done so already. Example:
https://www.snbforums.com/search/16...t&c[child_nodes]=1&c[nodes][0]=42&o=relevance
Like i say i read the wiki.
RT-AX88U_PRO -> release/src-rt-5.04axhnd.675x
make rt-ax88u_pro
Cant find rt-ax88u_pro.
