How to generate new certificate?
Simon W
Now that 380.66 onwards generates more complete certificates, how to I get it to regenerate?
More precisely: how do I remove the current (inferior) one so as to trigger the auto-generation?
Thanks.
Thanks.
Unless you changed the default behaviour, just reboot. It's generated at boot time.
what if I changed the default behaviour long time ago, so the cert isn't generated every reboot? how do I go back? it's way too long back, I don't remember.
Not 100% sure because I never really studied that part of the code, but my guess would be:
nvram set https_crt_save=0
nvram commit
reboot
Here's the method I recommended for my fork...I think it should be the same for the latest Merlin
The fastest way to generate a new certificate for import to your browser is via telnet/ssh.
nvram set https_crt_gen=1
nvram set https_crt_save=1
nvram commit
service restart_httpd
Close the current router window, and reconnect via https://192.168.1.1:8443 (or the url using your own router address and https port number). The browser will complain about an insecure connection due to a self-signed certificate. Use the procedure specific to your browser to accept the certificate and add it to the certificate store.
