case $(uname -m) in
armv7l)
PART_TYPES='ext2|ext3|ext4|jffs2'
INST_URL='http://pkg.entware.net/binaries/armv7/installer/entware_install.sh'
mips)
PART_TYPES='ext2|ext3|jffs2'
INST_URL='http://pkg.entware.net/binaries/mipsel/installer/installer.sh'
echo "This is unsupported platform, sorry."
esac
got itThis is NOT recommended, but it's your router.
Copy the file /usr/sbin/entware-setup.sh to jffs and then modify the PART_TYPES variables on line 23 and 27 to include the jffs partition:
Code:case $(uname -m) in armv7l) PART_TYPES='ext2|ext3|ext4|jffs2' INST_URL='http://pkg.entware.net/binaries/armv7/installer/entware_install.sh' ;; mips) PART_TYPES='ext2|ext3|jffs2' INST_URL='http://pkg.entware.net/binaries/mipsel/installer/installer.sh' ;; *) echo "This is unsupported platform, sorry." ;; esac
The script filters out all non ext* formatted devices.so by default, entware reqquires a flash drive intresting
that awesome, cause i wan to isntall abunch of scripts to the router that use ent ware and i was looking for a guide on how to mount it to a usb lol. I thought by default it install to the jfs folder.The script filters out all non ext* formatted devices.
Since you usually install additional packages on it, the size of the entware folder can dramatically increase.
The jffs partition is only 30/60MB, not much room to manouver.
In addition to that, you actively decrease the lifetime of that non-replaceable memory block considerably since it's read/write cycles have a finite number.
As I said, NOT recommended. Don't even think about installing AB-Solution in jffs, it won't fit.
Welcome To SNBForums
