YazFi How to let clients on different guest networks connect to each other?
tdai
I have a 2.4 GHz Guest Network (wl0.1) and a 5 GHz Guest Network (wl1.1), both with TWOWAYTOGUEST, ONEWAYTOGUEST, and CLIENTISOLATION set to false.
I want the clients on the two guest networks to be able to connect to each other. Is there a way to do it?
they should be able to, i think. check you don't have client isolation enabled on the main radio, and that any device firewalls aren't blocking traffic from other subnets
Thanks for your reply!
I checked that "Set AP Isolated" for both 2.4 GHz and 5 GHz radios are set to false, and I tested that devices on different subnets can talk to each other when they are not on the guest network, so there's no firewall on the devices blocking traffic from other subnets.
Is there anything you can see from the iptables maybe?
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
YazFiINPUT  all  --  anywhere             anywhere
INPUT_PING  icmp --  anywhere             anywhere             icmp echo-request
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
DROP       all  --  anywhere             anywhere             state INVALID
PTCSRVWAN  all  --  anywhere             anywhere
PTCSRVLAN  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             state NEW
OVPN       all  --  anywhere             anywhere             state NEW
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt:bootpc
ACCEPT     tcp  --  anywhere             Router.              ctstate DNAT tcp dpt:8443
INPUT_ICMP  icmp --  anywhere             anywhere
Chain FORWARD (policy DROP)
DROP       all  --  192.168.50.104       anywhere
YazFiDNSFILTER_DOT  tcp  --  anywhere             anywhere             tcp dpt:853
YazFiFORWARD  all  --  anywhere             anywhere
other2wan  all  --  anywhere             anywhere
NSFW       all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain ACCESS_RESTRICTION (0 references)
Chain DNSFILTER_DOT (0 references)
Chain FUPNP (0 references)
ACCEPT     udp  --  anywhere             192.168.50.107       udp dpt:5353
ACCEPT     udp  --  anywhere             192.168.50.101       udp dpt:5353
ACCEPT     udp  --  anywhere             192.168.50.106       udp dpt:5353
ACCEPT     udp  --  anywhere             192.168.51.50        udp dpt:5353
Chain ICAccept (0 references)
Chain ICDrop (0 references)
Chain INPUT_ICMP (1 references)
RETURN     icmp --  anywhere             anywhere             icmp echo-request
RETURN     icmp --  anywhere             anywhere             icmp timestamp-request
ACCEPT     icmp --  anywhere             anywhere
Chain INPUT_PING (1 references)
DROP       icmp --  anywhere             anywhere
Chain NSFW (2 references)
Chain OVPN (2 references)
Chain PControls (0 references)
Chain PTCSRVLAN (1 references)
Chain PTCSRVWAN (1 references)
Chain SECURITY (0 references)
RETURN     tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/SYN
RETURN     tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcpflags: FIN,SYN,RST,ACK/RST
RETURN     icmp --  anywhere             anywhere             icmp echo-request limit: avg 1/sec burst 5
DROP       icmp --  anywhere             anywhere             icmp echo-request
RETURN     all  --  anywhere             anywhere
Chain YazFiDNSFILTER_DOT (1 references)
Chain YazFiFORWARD (1 references)
YazFiREJECT  all  --  anywhere             anywhere
Chain YazFiINPUT (1 references)
ACCEPT     udp  --  anywhere             anywhere             multiport dports netbios-ns,netbios-dgm
ACCEPT     udp  --  anywhere             anywhere             multiport dports bootps,ntp
Chain YazFiREJECT (6 references)
REJECT     all  --  anywhere             anywhere             reject-with icmp-port-unreachable
Chain default_block (0 references)
Chain logaccept (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (0 references)
LOG        all  --  anywhere             anywhere             state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
Chain other2wan (1 references)
I disabled the 2.4 GHz guest network
My 2.4s are also disabled but I can't get them to connect for file sharing/smb. I've marked all the options that would allow communication but no dice. Thanks for the response though.
