Hi, I'm new here.
My first question, I searched in the forum but not found an answer to my doubts.
I have one wireless client on the guest network.
I would like to assign him the slowest possible priority.
All the other wired and wireless client on the LAN should not be affected by the traffic generated by the guest client.
I hoped to use QOS setting.
But not so clear how to define it in order to get the result.
If I put a rule to assign the guest client MAC address the "Lowest" priority then probably I need also to put similar rules for all the other clients (using higher priority).
But this is not easy to be managed and not clear how to use it together with additional service based rules.
Should I go with Tomato? (improved QOS and bandwitdh limitation)?
Thanks in advance for any suggestion.
