How to read the temperature without Merlin
Logi
I remember being able to read the temperature without using Merlin, I think it was native to AsusWRT, but I can't find it, I think it was in the Log or Admin section, any help will be appreciated, thanks
Login to the webUI and browse to http://router.asus.com/ajax_coretmp.asp.
If you have https enabled, you will have to modify the URL accordingly.
OE
This is much simpler and more elegant than using SSH.
But for everyone else, here's the OLD way of getting the temperature via SSH:
ARMv7 CPU:
cat /proc/dmu/temperature
ARMv8 CPU:
cat /sys/class/thermal/thermal_zone0/temp | awk '{print $1 / 1000}'
WiFi:
# 2.4GHz
wl -i `nvram get wl0_ifname` phy_tempsense | awk '{print $1 / 2 + 20}'
# 5GHz
wl -i `nvram get wl1_ifname` phy_tempsense | awk '{print $1 / 2 + 20}'
All results are in degrees Celsius.
WiFi:
# 2.4GHz
# 5GHz
For the sake of completeness, and for those with tri-band routers here is some code to get the temperatures for all available wireless radios:
Bash:
for radioIF in $(nvram get wl_ifnames)
do
   wl -i $radioIF status | grep Chanspec | cut -d ' ' -f 2-5
   wl -i $radioIF phy_tempsense | awk '{print $1/2 + 20}'
   echo
done
S VPN Killswitch without Merlin firmware ASUSWRT - Official 0
