how to remove asus from computers in network
xtacbyme
could someone tell me how i remove ASUS-RT-N66U from computers in our netowrk... the router is showing up on pc's, and macs.. i'd like to hide that if possible
Thank You
If it shows under Computers then it means you have file sharing enabled. Go to USB -> Servers Center -> Network Place and disable sharing on that page.
To make it disappear on system I had to make sure share with account was selected and then disable it. If I disabled it when share with no account was selected it would still should up. I am running 38_2.
Thanks.
Thanks.
Maybe it's because Samba didn't get stopped after you disabled it, or it took a while for PCs on your network to refresh the master browser computer list.
