HiHi there Any one can help me regarding my router firmware actually my router is running padavan Firmware so how can i switch my firmware to openWrt i have tried to reset my router but nothing works
Router Name : DIR-853 A3
Regards
Typical AI generated carp. If you want to post an answer to the original query then please do, but if you don't understand what is being asked, nor have any experience then please don't.Hi! I see you want to switch from Padavan firmware to OpenWrt for your DIR-853 A3 router. Here’s what you need to do:
- Preparation: First, make sure you have internet access and can connect to the router via an Ethernet cable. This is important to avoid wireless connection issues during the process.
- Download the firmware: Go to the official OpenWrt website and download the appropriate firmware for the DIR-853 A3. Make sure you select the correct version.
- Reset settings: Although you’ve already tried resetting the router, make sure you do it properly. Press and hold the reset button on the router for 10-15 seconds while it’s powered on.
- Flashing process: Access the configuration interface of the Padavan router, usually at 192.168.1.1 or 192.168.0.1. In the firmware section, select the OpenWrt firmware file and follow the on-screen instructions. Do not turn off the router during this process.
- Configuring OpenWrt: After the flashing process is complete, the router will reboot. Access the new OpenWrt interface at 192.168.1.1 and set it up as you like.
Welcome To SNBForums
